holley intake
Old April 19th, 2007, 09:02 PM   #1
cali 5.0 is on a distinguished road
holley intake
ive got an 89 gt tht is stock right now, ima about to order my holley systemax2 intake manifold and a 70mm throttle body and 1.6 rocker arms, ive got 3.73 gears and full exhaust,..wht kinda power to the wheels do u think i'd be making... ive also got a jet perfomance chip.
this is all temporary, after i put those on im goin to start saving for a 331 or a 347 stroker, havent decided yet but im gonna get a custom cam and i want to run a supercharger with maybe about 10 psi... what kinda heads should i b looking into with this set up??
89 gt 3.73 gears, full exhaust, holley system max2 intake manifold, 70mm throttle body, jet chip
Old April 19th, 2007, 10:46 PM   #2
Racinjason81 is on a distinguished road
A custom cam would be a great idea.Afr 185 heads work really good and
would be perfect for a stroker and would work good for a 302.
Heres a real funny video
youtube.com/watch?v=ojB7KkaR03I
VTEC stands for Very Torqueless Economy Car
Honda stands for Hold On Not Done Accelerating
1991 LX 5.0 H/B(T-70 turbo coming soon)
Old April 19th, 2007, 10:50 PM   #3
95opal's Avatar
95 opalfrost gt
95opal will become famous soon enough
I wount even put it on if you still have the stock heads.
5.0 magazines
94-04 performance mustangs feature car! Fall 2010
Old April 19th, 2007, 11:34 PM   #4
nolife's Avatar
91GT, 88GT, 02GT
I highly suggest using studs for at least two of the mounting bolts for that upper intake. The hole just behind the distributor and the one under the throttle body. Clearance to the driver side valve cover is close as well, stock valve covers will be fine, anything 1/2 inch or more larger and it will be very tight. Holley does not suggest using a spacer either but I think I saw someone selling one.
Old April 19th, 2007, 11:53 PM   #5
clearance for wht the intake manifold???
Old April 19th, 2007, 11:56 PM   #6
nolife's Avatar
91GT, 88GT, 02GT
Yes, there is about 1/2 inch of space between the upper intake and the drivers side valve cover..
Old April 20th, 2007, 12:01 AM   #7
nolife's Avatar
91GT, 88GT, 02GT
Crappy quality photo here but you can see that it is a tight fit.
Old April 20th, 2007, 02:59 PM   #8
does the intake manifold come with the gaskets for it or will i hav to buy them seperately??
Old April 20th, 2007, 11:54 PM   #9
nolife's Avatar
91GT, 88GT, 02GT
Mine was not originally bought by me so I don't know. I did recently replace them all though.
I got the BBK-1572 kit for my TB, EGR, IAB, and EGR spacer and HLY-108-80 for the upper to lower intake gasket from Summit.
Threads Similar to: holley intake
Holley carb help! JONJON 5.0 Mustangs 4 October 27th, 2007 09:54 PM
bbk holley and edelbrock cali 5.0 5.0 Mustangs 19 October 20th, 2007 11:39 PM
holley carb 9teen65coupe Classic Mustangs 10 August 22nd, 2007 07:15 AM
Holley or Trickflow cali 5.0 5.0 Mustangs 3 November 11th, 2006 10:50 PM
Holley or Trickflow Tony_90fox 5.0 Mustangs 14 November 2nd, 2006 12:15 PM
