88 Mustang Needs shocks/struts
I bought the car last March and have only had to do a few minor things with it. Waterpump tire ignition switch. But the ride is rough as hell right now and was advised to get shocks/struts lesschwab quoted me at around 454$ for the job. If you were in my position would you get it done. I have a leg injury and hoping this would make it ride better. And become more comfortable for me. The brand they said was kyb I believe.
1991 Mustang LX 5.0
This is probably what they are putting on your car.
Point made in less than a few hours with minimal response. http://www.moddedmustangs.com/forums...ml#post4465184 |
1991 Mustang LX 5.0
Also, they are the same one's I put on my car, but I lowered it at the same time. And since lowering the car makes the ride a little harsher, I couldn't tell you how good they are. But I can tell you this. It didn't ride worse after lowering it with those shocks/struts. So they must not be bad, but there's always better. If you have to pay to get it done, ask him how much labor that is, then tell him you'll pay him that amount if you can provide your own parts. I have a buddy that owns his own shop and he hates people that do that cuz he doesn't get his mark up on parts, but I can tell you it's a very healthy markup. If someone tells him they are providing parts before they ask for labor cost, he adds more $ in. So make sure you get him to tell you labor cost first. And I would not, under any circumstance, pay more than 1 1/2 hours labor on that. And that's like giving them a free 1/2 hour.
1992 Mustang LX
13.0 @ 105
I have Eibach lowering springs along with my Tokico struts/shocks and it's stiff as hell. That's all I can say though, I've never compared with other brands.
As I lay rubber down the street I pray for traction I can keep But if I spin, and begin to slide Please dear God, protect my ride |
#5 | |
1991 Mustang LX 5.0
If you didn't need an alignment before, you won't need one after. Replacing the front struts doesn't change caster/camber. That plate is locked in place and the strut centers itself in it.
1991 Ford Mustang GT
Really ? Ive always been told that when you change your front struts an alignment is the next thing you do
Yeah they stressed the alignment pretty hard to me. How do you tell if you need to replace the springs.
1991 Mustang LX 5.0
Springs can wear out, but I would say if they aren't broke, just let them be. And as far as the alignment... Many vehicle's yes, but not this one. The way it bolts on makes it pretty impossible to be off. Maybe a fraction of a mm or something, but otherwise not really possible.
Would buying the chilton book be a good idea in this case to find out how to do it? I'm not as handy as I'd like to be.
You dont need a book to change your shocks and struts. But the book is always good to have around. I used mine all the time.
The struts are 3 bolts each and the shocks are two bolts each...
Ok, shouldn't be to hard. I'll do a bit more searching on what I'll need to do the job and hopefully post results
1991 Mustang LX 5.0
Nothing better than the satisfaction of doing something yourself... and keeping the money in your pocket. As Ryan said, it's simple to change these, but having a chilton's or haynes around isn't a bad idea for quick reference and not having to search through lots of bs on the internet to find what you're looking for.
#14 | |
Threads Similar to: 88 Mustang Needs shocks/struts
| Shocks/struts | poranksta | 99-04 | 6 | June 14th, 2010 01:01 PM |
| what do to with used struts/shocks | hardhitter | 99-04 | 10 | June 25th, 2008 11:55 AM |
| Shocks Struts, and Quad Shocks? | 2000roush | 99-04 | 2 | December 4th, 2007 07:27 PM |
