Noob needs help with MAF.
Old January 30th, 2011, 11:16 PM   #1
d_Ryan's Avatar
d_Ryan is on a distinguished road
Ok, so this is my first post on modded mustangs, so bare with any of my idiocy. I've tried to search but im kind of coming up baffled. I have an 86' GT which used to have a MAF conversion done. But as of right now there is no harness. I've been told that it is hurting performance. As of right now, is my car just using Speed density? What do i need to get the maf working. Do i need a new computer??? Sorry, for making a whole post but i seem to be coming up short. Here is a picture of the MAF and the "computer?". BTW, its on an AEM intake and im running 24lb. injectors.
Old January 30th, 2011, 11:55 PM   #2
ryanw's Avatar
1991 Ford Mustang GT
Originally Posted by d_Ryan View Post
I have an 86' GT which used to have a MAF conversion done. But as of right now there is no harness. I've been told that it is hurting performance. As of right now, is my car just using Speed density? . BTW, its on an AEM intake and im running 24lb. injectors.
you said used to have the mass air harness ? why was it disconected and removed ?
Trick Flow R intake,
jba headers, 2 1/2" x pipe
flowmaster super 10 mufflers,
255 fuel pump,
3:27 gears
Old January 31st, 2011, 03:20 AM   #3
AdderMk2 will become famous soon enough
Send a message via AIM to AdderMk2
the picture you posted of the computer does not show the catch code, so we cannot tell if it is a SD or MAF ECM.
A MAF car will not run in a "SD mode" by simply unplugging the maf. So if your car has a MAF ECM in it, and runs like sit... its because the maf needs to be... i say again... NEEDS to be plugged in.
[URL="http://providence.craigslist.org/cto/2148862880.html"]1994 Cobra For Sale[/URL]
[SIGPIC][/SIGPIC]
[QUOTE=Timm10221]Its only a 10 inch Tach that sits right in the center of the dash with LED lights and a Spinner bezel that has dimonds and gold plating.. And when you hit 4500 plus is sounds off (AAHHH SHITT) :cool:[/QUOTE]
Old January 31st, 2011, 10:54 AM   #4
d_Ryan's Avatar
Before i bought it (just recently), it had a maf conversion, but the seller wanted to take it off. He, i guess took off the harness, but forgot the maf? I definatley wouldnt say it runs like shit. It still runs 14s in the 1/4, and runs perfectly smooth, but it does have a little trouble idling consistently. So how do i know if the ECM is SD of MAF? Like, which catch codes should i be looking for??
1986 Mustang GT Hatch: Hurst STS 5-Speed. 3.73 gears. MSD Coil and Cap. JBA headers.Full suspension, Global West subframe connectors.Aluminum Radiator, Driveshaft, and Flywheel. Fidanza Clutch.70mm TB. AEM intake.
Old January 31st, 2011, 04:23 PM   #5
the white sticker on the end of the computer will tell us alot. we need to know what code is on it. Should be a letter number letter like X#X
[SIGPIC][/SIGPIC]
Old January 31st, 2011, 07:48 PM   #6
d_Ryan's Avatar
Old January 31st, 2011, 08:07 PM   #7
ryanw's Avatar
I think thats your stock SD ecm. not sure though
255 fuel pump,
3:27 gears
Old January 31st, 2011, 10:33 PM   #8
yup yup E6SF is a 1986 year produced piece. stock.
the 24# injectors are currently a root cause of your car running shitty
[SIGPIC][/SIGPIC]
Old January 31st, 2011, 11:12 PM   #9
ryanw's Avatar
So id put the 19lb injectors on, or finish the mass air conversion. And with the mass air make sure your maf is calibrated to the 24lb
255 fuel pump,
3:27 gears
Threads Similar to: Noob needs help with MAF.
Noob luisxsvt 5.0 Mustangs 4 October 1st, 2011 01:34 AM
Noob from NC kwikcoupe New Members Introductions 3 May 4th, 2010 09:44 PM
Noob 89pigeontoe New Members Introductions 6 April 16th, 2010 12:48 AM
i know im a noob so noob questions Dratomic 5.0 Mustangs 27 February 5th, 2008 09:28 AM
Noob Saying Hello scramblr 2005 - 2010 16 May 3rd, 2007 12:21 PM
