would my block hold up? how much hp should i expect?
Old January 31st, 2011, 12:50 PM   #1
1990 Mustang GT
rocket is on a distinguished road
I was wondering if my stock block would hold up to everything i would like to add.
Currently i have Vortec S-trim V-3, BBK headers with x-pipe and flowmasters, and the smog eliminator kit. I put a new clutch in it and only got about 350miles on it before the winter came and now waiting for the snow to melt before i can get it dyno tuned, and actually find out what power its running currently.
Was thinking about trickflow cam, heads, and intake as well.
Would all of this work with my stock block or would that be to much power?
'90 GT
Vortec SI with pro-pipe
Eibach pro kit
KYB adjustable shocks/struts
BBK headers/x-pipe/american thunders
Old January 31st, 2011, 04:36 PM   #2
91Mustang GT's Avatar
1991 Mustang GT
Sloowwwww
91Mustang GT can only hope to improve
I wouldn't take a stock block over 500 crank/450 wheels. These blocks like anyone else will tell you are unpredictable some hold up to only 300 and some can go as high as 600 (Bet that one didn't last so long though lol!) How much boost do you want to run on that Vortech, what heads and intake are you going to run?
Black 'Stang Crew #1337
Old January 31st, 2011, 05:31 PM   #3
1990 Mustang GT
I believe im running around 8lbs and think trick flow was the way I wanted to go. Im not sure what im running now for HP as I havent got it final tuned or dynoed. Was wanting 500miles on the clutch first.
'90 GT
Eibach pro kit
Old January 31st, 2011, 07:08 PM   #4
1slo5.0's Avatar
1990 Mustang LX
9.36@143 mph
It will hold up fine as long as the tune is good. As it sits it is making about 300hp to the tire. With heads, cam and intake you will be looking at 450+.
Threads Similar to: would my block hold up? how much hp should i expect?
Last thread of the night..Block tat will hold 600hp? b-on-b 5.0 5.0 Mustangs 13 February 9th, 2010 12:48 AM
how much should i expect to pay?? cbrown54 99-04 21 May 30th, 2008 02:59 PM
Which block wil hold 500rwhp? kratos2250 5.0 Mustangs 28 May 4th, 2008 09:01 PM
Will stock block hold up? kratos2250 5.0 Mustangs 47 May 3rd, 2008 09:29 AM
Is there a Block that can hold more HP than the stock 5.0L out there? The Novice 5.0 Mustangs 24 April 18th, 2008 10:25 AM
