Crankshaft Balancing
Old April 21st, 2007, 12:47 AM   #1
Zak
Zak is on a distinguished road
Is there anybody that has dropped in a crank into a motor without balancing it, and what was the result?
The reason I'm asking this question is that I have a 347 Eagle crank with 3.4" stroke installed already but yet I haven't balanced it. Only the bottom end is assembled so it's not too late to dismantle it again for a balance job.
I have another 331 SCAT crank with 3.25" stroke that has been balanced with a .28oz harmonic damper & a flywheel, but the rods & pistons were not used in the balance job at that time. I'm sure of that.
I came across this article and it just woke me up:
Muscle Car Magazine: Balancing
Thanks for your advices.
Old April 21st, 2007, 01:00 AM   #2
fogged306's Avatar
89 GT
I've been told by everyone I know to balance the crank before you put it in. I dont know from experience but these guys have raced everything under the sun and I trust them. Im actually taking my crank to get balanced at the end of the month, its the only thing stopping me from assembling my motor but I've been told it will be worth the wait. I also heard the motor will rev a little quicker with a balanced rotating assembly but im not sure how true that is.
Old April 21st, 2007, 04:37 AM   #3
Zak
I would believe that because there will be less stress on the bearings when the crank is properly balanced. Looks like I have to do a rework but as you mentioned, it is worth it.
Old April 21st, 2007, 05:29 AM   #4
1slo5.0's Avatar
1990 Mustang LX
9.36@143 mph
Balance the entire rotating assembly, not just the crank. This will make the bearings and parts live longer and reduce or eliminate vibration. You'll probably gain a few horsepower in the process as well. I don't put any engine together without having the rotating assembly balanced. Doing it any other way is just a half ass hack job. Balancing is cheap.
Old April 21st, 2007, 06:00 PM   #5
fogged306's Avatar
89 GT
Sorry to hijack the post but does anyone know roughly the cost of having the entire rotating assembly balanced?
Old April 22nd, 2007, 01:06 AM   #6
1slo5.0's Avatar
1990 Mustang LX
9.36@143 mph
Usually a couple hundred dollars.
Old April 22nd, 2007, 04:02 PM   #7
86er's Avatar
150 out here in bama, glen sheppard, use to build the allison brothers nascar motors,
Just a truck
Old April 22nd, 2007, 10:39 PM   #8
Clockman is on a distinguished road
dumb question how do they balance the entire rotating assembly is it in the block with pistons? being balanced?
Old April 22nd, 2007, 11:11 PM   #9
1slo5.0's Avatar
1990 Mustang LX
9.36@143 mph
Not in the block. Good machine shops have equipment to weigh and balance everything.
Old April 22nd, 2007, 11:30 PM   #10
jam77's Avatar
1987 Mustang GT
jam77 is on a distinguished road
crankshaft balancing
they have fixtures that attach to the rod journals that are filled with lead shot that are the exact weight of your pistons and rods. Than the crank and fixtures are put on a machine that pick up the slightest movement then the machinist will either add weight to the crank or take weight by drilling the crank. my dad owned an automotive machine shop for 24 years
Threads Similar to: Crankshaft Balancing
Zero Balancing A Flywheel Please Help Me ASAP 99v6stang V6 Mustangs 2 November 15th, 2007 06:21 PM
need help with balancing sixpack 5.0 Mustangs 1 September 25th, 2007 08:52 PM
Crankshaft Help PLEASE!! ymerej47 5.0 Mustangs 5 September 9th, 2007 06:10 PM
balancing have a few questions wendyman 5.0 Mustangs 3 September 6th, 2007 01:57 PM
Engine Balancing MySallyMI 99-04 4 July 23rd, 2006 02:03 PM
