computer problem
Old February 5th, 2011, 11:02 PM   #1
91 ford mustanglx
mustanglx is on a distinguished road
computer problem
I have a 1984 ford mustang 302, engine is from a 1977 ford truck with the non H.O. firing order. What would be a good engine computer. it has a t5 transmission in it now, perfer mass air, but would run speed density if i had to.
Old February 6th, 2011, 04:03 AM   #2
Ohsplat's Avatar
1983GT
No motor or trans
Ohsplat is on a distinguished road
Send a message via Yahoo to Ohsplat
If you have a HO computer, and NON HO motor cant you just swap the firing order on the dist cap? If not you can get computer from a cougar, grand marquis, thunderbird, ford LTD, pretty much any car with a non HO 302 i would imagine would work. If you have a carbed car which i think a 84 was then you cant use a FI computer. Id look for a computer from one of the cars i listed from 79-85.
Old February 6th, 2011, 04:48 AM   #3
fogged306's Avatar
89 GT
You would be much better off swapping in an HO cam and changing the firing order to the HO. For a Manual car look for an A9L which is a MAF 5 speed computer. That will only work with the HO cam/firing order swap though.
Like mentioned the 84 was carb'd. I'm assuming you know this already and have a donor EFI setup and are missing a computer?
Old February 6th, 2011, 10:40 AM   #4
91 ford mustanglx
I was told that a crankshaft and camshaft have to be changed to be a H.O. but if just the camshaft has to be changed and move wires around i will do that. it does have the t5 in it and it was a carb car just want fuel injection now i was thinking of using the A9L computer.
Old February 8th, 2011, 10:30 AM   #5
Authorized Vendor
Matt Cramer's Avatar
Matt Cramer is on a distinguished road
Firing order can be changed by moving the injector wires and spark plug wires. What are the specs on the engine - is it pretty much stock, or does it have any mods on it?
Old February 8th, 2011, 11:29 AM   #6
fogged306's Avatar
89 GT
Cam needs to have the correct firing order too.
Old February 8th, 2011, 11:30 AM   #7
fogged306's Avatar
89 GT
Nope, there's no difference in the crank between a non-ho and an ho engine. If you put in any aftermarket performance cam or a stock ho cam in and an A9L, you'll be good to go.
Threads Similar to: computer problem
Please help!!! Computer problem!! Blitz34 99-04 21 September 8th, 2010 10:37 PM
computer problem skuzzy The Clubhouse 12 March 18th, 2010 10:01 PM
Okay Computer problem Onemanzu The Clubhouse 8 July 20th, 2007 12:28 AM
computer problem fastford3388 5.0 Mustangs 3 July 18th, 2007 02:10 AM
Computer or MAF problem? shurb125 5.0 Mustangs 36 January 31st, 2007 09:32 PM
