1988 gt
Help with 88 gt non starting issue
I started my car last week to let it warm up, it ran for 10-15 mins, i went in to grab my phone, i heard the car die. I go back out try to start it it runs rough, give it gas it dies. I decided to go ahead and change the fuel pump and fuel filter, hadnt done it yet. Now it turns over, you crank it 4x, it starts for 10 secs, dies, crank 4x, starts runs 10 secs, dies. after 2 or 3 times, it won't start anymore. i hadn't changed anything on the car, was driving fine, just died., Any help would be greatly appreciated. Tomorrow i'm gonna clean iac, and replace coil., thought i might replace my key switch too, seems lose.
Better than Drugs!
97 Cobra makin' women wet
Decent @ A fast one
well it could be a the pick up coil, pip, in the distrubutor. do a little search on it
96 GT-sold 98 GT-05 katrina victim-parted 90 GT-traded 98 GT-traded 98 GT-parted 94 GT/Cobra-sold 95 Cobra Saleened-sold 97 Cobra-knock -sold 99 GT-knock-sold 97 Cobra-sold 96 Cobra-nothing wrong but stock! MM Cobra member 969
1989 Mustang GT
~14@99 (b4 turbo)
codes? would def narrow the problem(s)
306 w/ 8.9:1 ON3 70mm turbo kit - 9#'s boost arp chromoly studs 47# FRPP - 255 walbro 3.73 - tremec 3550 - zoom hp kevlar clutch msd 6a + blaster coil lowered. sfc. HID delete egr-smog-cats-a/c-foglights battery reloc QuarterHorse, BE, EA |
1988 gt
no codes, no check engine light, i'm going to change the coil tomorrow., and my ignition switch was tampered with[attempted theft], about a year ago.,
Better than Drugs!
Decent @ A fast one
you sure it didnt surge and die?
1988 gt
no, not sure. it will idle for like 10 secs, then dies like you shut it off
1989 Mustang GT
~14@99 (b4 turbo)
sounds like how my car ran when the MAF sensor connector was loose. but im not sure about speed density setups....
1993 5.ohhhh
12.97 @140mph
You scanned for codes? Just because they don't flash doesn't mean they don't exist. Don't change the pump and the filter until you know whats wrong. Thats setting yourself up for failure. Why does everyone think the fuel filter solves everything?
02 Pewter z28, hoosiers/lid/exhaust/spray...125mph 1993 gt Sold, already missed ![]() --Moates Quarter horse $225-- --Cobra intake $150-- --tremec 3550 bell and shifter $1100--
89 GT
Put a fuel pressure gauge on it and watch it when it stalls. See if maybe you're losing fuel. Def don't just start throwing parts at it.
Another thing you can try is to check for spark when it won't start. You need to isolate the issue to either a fuel or an ignition problem before you do anything else. |
1989 Mustang GT
~14@99 (b4 turbo)
more than the fuel filter i always get "probably water in the gas tank". which basically means "i dont really kno..."
1988 gt
i already had plans to upgrade the fuel pump, was running a stock pump on the fresh 306, i did switch it over to the MAF setup., and i would never install a fuel pump and not change the filter
What is the fuel pressure when the car dies? Does it have spark when it dies? Is there a performance chip in the computer?
FYI, your plan is going to cost you a bunch of money. Diagnose the problem and then fix the problem. Don't just throw parts at it until it is fixed. All that will do is cost you time and money.
1990 mustang gt
No one has mentioned the fuel pump relay
Burning Rubber in the 5.0 http://www.youtube.com/watch?v=mKGSmRkKQcM95 95 mark8 lsc 95 tbird v8 90 mustang gt 07 silverado v8 08 yamaha r6 to be continued........ foxbodyperformance.com is the way to go |
1988 gt
ill check the fuel pump relay. someone needed my fuel pressure guage more than me, apparently, so i have to go get a new one, yes there is spark when it dies
the same thing happen to me, found out my fuel gauge was off and it had no fuel, yea you feel like an idiot but hey now you know.Try some gas.
91 Mustang GT
1991 sliver GT
Check your fuse linkage coming from off the yellow wire on the solenoid next to the coil, That goes to the computer and it then tell the computer to give spark to the coil. Mine to a shit on me bout 7 hours ago.
#17 | |
1988 gt
thanks for all the advice guys, i'm still working on it, but it's snowing today.
1988 gt
I finally got it running, the fuel pump wasnt pumping?, i submerged it in fuel,and it now works fine.I let it run for about 30 mins, does fine, now i have about two days of reassembly to get to drive it. thanx again for the help
Threads Similar to: Help with 88 gt non starting issue
| Starting Issue | kay15ace | 94-95 | 10 | June 22nd, 2010 01:31 PM |
| Starting issue | 97GSTANG | 5.0 Mustangs | 10 | September 3rd, 2009 02:22 PM |
| Help Please!!!!! Starting issue. | orangerider32 | 5.0 Mustangs | 4 | October 29th, 2008 10:46 PM |
| starting issue | white nite | 5.0 Mustangs | 28 | April 16th, 2008 02:04 PM |
| Issue With Starting | JustinSane | V6 Mustangs | 6 | January 11th, 2008 07:56 PM |
