sputtering/falls on its face under load only - Page 2
Old February 7th, 2011, 06:59 PM   #21
zombiekiller1987 is on a distinguished road
Originally Posted by fogged306 View Post
Well that's a given, but you should be able to crutch the car to the tuner.. at least I've seen people do so in the past with boost and 42's. You may have things working against you though like the cam, and your elevation and that C&L, or you may just have something stupid preventing you from getting it to run decent enough to drive.
I would use the piston stop to check the timing marks. Once you're certain of timing, verify your fp, and if you still can't get it to move my next guess would be the C&L.
is the c&l a bad choice? i've been told otherwise...any suggestions on a calibrated maf?
Old February 7th, 2011, 07:39 PM   #22
ryanw's Avatar
1991 Ford Mustang GT
ive heard from alot of people that C&L suck really bad, but ive never used one.
Trick Flow R intake,
jba headers, 2 1/2" x pipe
flowmaster super 10 mufflers,
255 fuel pump,
3:27 gears
Old February 7th, 2011, 08:29 PM   #23
1992 Lx
11.39@119.24
I'm the only member of MM who likes c and l. But I don't have a slowtec pushing air into my motor
Old February 8th, 2011, 08:05 AM   #24
flattusmaximus78's Avatar
1993 5.ohhhh
12.97 @140mph
Cause your a vajay.
02 Pewter z28, hoosiers/lid/exhaust/spray...125mph 1993 gt Sold, already missed
--Moates Quarter horse $225--
--Cobra intake $150--
--tremec 3550 bell and shifter $1100--
Old February 8th, 2011, 08:14 AM   #25
1slo5.0's Avatar
1990 Mustang LX
9.36@143 mph
Originally Posted by zombiekiller1987 View Post
what up guys...new to this site got some issues with my setup that i've been working on for too long (over a year)!
First of all here is my setup:
ford racing 351 crate, afr 185s, e cam, 1.6 svo rockers, holley system max manifold,summit 42lb inj.,walbro 255lph f/p, BBk adj fpr, 75mm t/b, no egr, 76mm c&l maf housing for 42lb inj. w/ stock sensor,msd blaster coil, msd cap and rotor stock dizzy, new icm, frpp 9mm wires, procharger p600 10lb pulley oil fed with god speed 30x12x3 i/c, msd 6al, aem wide band uego, tko 600, zoom stage 3, pro 5.0, detroit locker w/4.10s, moser 31s.
my problem is i've been building this thing up for a while...long story short..i got the setup rolling now i have not gotten it tuned yet but it falls on its face immediately under power train load...i put new gas in after a year of sitting with lucas fuel stabilzer, set the timing as close as 10BTDC w/spout out, a/f ratio at cold idle is about 12.2-13.3,pulling 8-10" vacuum, fuel press is around 30psi at idle ...i'm scratching my head trying to figure this out...im not sure if my balancer ring has moved my crank pulley doesn't seem to wobble...anyone have any advice??? i need to at least get it rolling to take it to get tuned ya know?
You might need to trailer the car somewhere to have it tuned. Its going to be hard for anyone to diagnose this over the internet because it could be many things.
C&L is junk and it would not suprise me if that MAF was causing your problems. I've seen C&L meters cause problems like this many times over the years.
Threads Similar to: sputtering/falls on its face under load only
Saleen Supercharged GT Falls on its Face, Clutch!? jonwrong 99-04 19 May 25th, 2010 10:25 PM
Car falls flat on its face when on a tire LBSRACING 2005 - 2010 53 February 6th, 2010 04:51 PM
84 Capri revs fine but falls flat on its face under load daveconner1984 5.0 Mustangs 4 August 18th, 2009 05:32 AM
Will Not Stay Running - Car Falls On Its Face 95stroker 94-95 21 April 27th, 2009 09:08 AM
Falls Flat On Her Face at 4500rpms Vamp89 5.0 Mustangs 1 May 6th, 2006 03:51 PM
