Control Arm Bushings
Old February 6th, 2011, 10:32 PM   #1
orangestang42's Avatar
1995 Mustang GT
orangestang42 is on a distinguished road
I want to replace my control arm bushings can someone point me in the right direction on where i can find them, i looked on autozone's website and they have more than one and i confused, it says they have an upper and a lower, but i thought there was only 2 control arms, 2 that hook to the differential, one on each side and it bolts to the frame underneath the car. i do believe i need 4
thanks
guys
Old February 6th, 2011, 10:45 PM   #2
ryanw's Avatar
1991 Ford Mustang GT
you have 4 controlling arms. 2 upper and 2 lower, the ones your talking about are the lowers.
Trick Flow R intake,
jba headers, 2 1/2" x pipe
flowmaster super 10 mufflers,
255 fuel pump,
3:27 gears
Old February 6th, 2011, 10:49 PM   #3
ryanw's Avatar
here just to show you 79-98 MUSTANG BBK2526 REAR UPPER LOWER CONTROL ARMS TMD - eBay (item 170596155108 end time Feb-26-11 15:46:59 PST)
255 fuel pump,
3:27 gears
Old February 6th, 2011, 11:02 PM   #4
1995 Mustang GT
oh ok cool, what are the ones that run alongside the car..are those the long ones in the picture? and how many bushings do i need for the upper, it looks like there is only 2 total in the picture but i thought there was 4, it looks like there is 4 on my car, one on each end
and also under autozone's website they have them listed as Control Arm Bushing-Front
and Control Arm Bushing-Rear... which is which?
Old February 6th, 2011, 11:41 PM   #5
ryanw's Avatar
if you get under your car you will see that all 4 control arms run from the body to the rear end. the small ones are on top of the rear end and can only be seen if you crawl under the car. As for the bushings i dont know
255 fuel pump,
3:27 gears
Old February 6th, 2011, 11:44 PM   #6
1995 Mustang GT
yes i am looking to replace the ones on top of the differential, the two small ones, i did try to look up some how to in the install and people are sayin the bushings are a pain in the ass to get out
and thanks ryan ur always help
Old February 6th, 2011, 11:46 PM   #7
ryanw's Avatar
Im gessing that they need to be pressed in
255 fuel pump,
3:27 gears
Old February 7th, 2011, 02:00 AM   #8
this tool makes it a shit ton easier to do
Rear Upper Control Arm Bushing Tool [MMT-1] : Maximum Motorsports, the Latemodel Mustang Performance Suspension Leader!
Old February 7th, 2011, 02:50 AM   #9
The Big Spoon
jessemachone's Avatar
88 5.0 5 Speed Notch <><
never fast enough
jessemachone is a glorious beacon of lightjessemachone is a glorious beacon of lightjessemachone is a glorious beacon of lightjessemachone is a glorious beacon of lightjessemachone is a glorious beacon of light
dude, get the rear to hang pretty low and run a drill tinto the rubber in a bunch of spots and the urbber will just push out after that. you can peel the rest of it away with a screw driver. after that, you just hamer in urathane replacement ones. you hammer them into the old shell of the factory ones. it isn't that hard to do.
when lowering your rear, disconnect the rear brake line because it will not be long enough for you to drop the rear very far. I replaced the bushings in the rear when the rear was out of the car but I imagine it can be done with it installed. (or mostly installed for that matter) You will have to unbolt the upper arms from the rear so i think you will have plenty of room to drop that thing far enough to do the work.
as far as the rear control arms are concerned, they are crap. save for a new decent set. if you replace the factory bushings in your factory arms, you will have crappy arms with nice bushings. I almost went that route because I was wanting to save some coin.... it would have been such a waste of time.
Black Stang Crew
Originally Posted by 302Army187 View Post
old 5.0's are like a box of chocolates.......... never know what your gonna get
Old February 7th, 2011, 02:51 AM   #10
The Big Spoon
never fast enough
bah, who needs that when you have a baby sledge?
Black Stang Crew
Old February 7th, 2011, 07:44 AM   #11
1slo5.0's Avatar
1990 Mustang LX
9.36@143 mph
Why not just replace the control arms? The factory control arms are junk anyway. That should be one of the first modifications done to a fox body Mustang, control arm replacement.
Old February 7th, 2011, 08:22 AM   #12
1995 Mustang GT
well i dont have a foxbody but i get the point, ok how much would i be looking at for rplacing the uppers, im on a budget right now and would much rather replace the lowers another time
Old February 7th, 2011, 08:30 AM   #13
1slo5.0's Avatar
1990 Mustang LX
9.36@143 mph
Same control arms.
Old February 7th, 2011, 06:57 PM   #14
FastStang91Lx's Avatar
1991 Mustang LX 5.0
Same platform til 04 for that matter.
Old February 7th, 2011, 08:01 PM   #15
ryanw's Avatar
replace the lowers first.....when you replace them pull them out one at a time. if you pull them all out at one time your going to have a hell of a time putting it all back together
255 fuel pump,
3:27 gears
Old February 7th, 2011, 10:30 PM   #16
1995 Mustang GT
ok, and the lowers would be the ones that i am not referring too? lol, and do they part the kits on ebay, because all the ones i have found are all 4
Old February 7th, 2011, 10:34 PM   #17
1991 Mustang LX 5.0
You can buy uppers and lowers seperately if that's what you are asking.
Old February 8th, 2011, 08:30 AM   #18
1995 Mustang GT
yes thats what i am asking, but i dont think i can get them locally at like auto zone or something
Threads Similar to: Control Arm Bushings
Control Arm Bushings 89StAngerLX 5.0 Mustangs 8 May 3rd, 2008 12:04 AM
control arms or just bushings? crappy_head 99-04 2 September 15th, 2007 05:51 PM
Control Arm Bushings? CMcD 5.0Lx93 5.0 Mustangs 5 August 8th, 2007 12:37 AM
control arm bushings angermgt 5.0 Mustangs 5 May 15th, 2007 07:30 PM
Lower Control Arm Bushings cali 5.0 5.0 Mustangs 3 November 13th, 2006 06:04 AM
