91GT knocking noise under Valvecovers
LinkBack (1) Thread Tools
Old February 7th, 2011, 11:22 AM   1 links from elsewhere to this Post. Click to view. #1
FB5.0 is on a distinguished road
my 5.0 has been making a knocking noise under the driverside valve covers. Its equiped with an E-cam and some people told me it may be my lifters. I bought a new set of lifters and put them in but the knocking is still there.
Anyone know how I can find my problem?
Old February 7th, 2011, 01:03 PM   #2
1992 Mustang LX
13.0 @ 105
StangBanger302 will become famous soon enough
Post a video. Engine could have blown. Maybe a rod knock. No way of telling if we can't hear it.
As I lay rubber down the street
I pray for traction I can keep
But if I spin, and begin to slide
Please dear God, protect my ride
Old February 7th, 2011, 03:39 PM   #3
VM0824's Avatar
1989 Mustang GT
~14@99 (b4 turbo)
VM0824 is on a distinguished road
is it runnin like crap? my truck ran like crap, opened up valve covers and saw 2 bent pushrods which didnt have the rockers set on them anymore. they were punchin the crap outta my roller rockers and the top of the valve cover and making a sort of knocking sound
306 w/ 8.9:1
ON3 70mm turbo kit - 9#'s boost
arp chromoly studs
47# FRPP - 255 walbro
3.73 - tremec 3550 - zoom hp kevlar clutch
msd 6a + blaster coil
lowered. sfc. HID
delete egr-smog-cats-a/c-foglights
battery reloc
QuarterHorse, BE, EA
Old February 7th, 2011, 03:52 PM   #4
gripthenboost's Avatar
91 Mustang GT
1991 sliver GT
gripthenboost will become famous soon enough
9 times out of 10 its a loose rocker. Pull it off it only takes less than 30 mins to pull and check and its something u can do yourself.
Old February 7th, 2011, 03:52 PM   #5
1slo5.0's Avatar
1990 Mustang LX
9.36@143 mph
Broken springs, wore out lifters, bent pushrods, cracked or broken rocker arms, etc. Do you know if the springs were changed when the cam was put in? If not, now would be a good time to put the correct valve springs in.
Old February 7th, 2011, 05:09 PM   #6
BULLET20XD's Avatar
BULLET20XD is on a distinguished road
Mine did the same noise, i checked it numerous time. My top end was good, it was my bottom end. #3 main spun, and #4&8 rod spun and that was my terrible knock. Oil pressure will vary or drop completely!
1990 LX 5.0
2000 Expedition
2002 Honda Accord
One tea cup Chihuahua guard dog!!!!!!!
Old February 7th, 2011, 08:47 PM   #7
I put in new lifters in already yesterday but the knocking is still there. The pushrods didn't seem to be bent or damaged and I torqued the rockers to their specs and the springs haven't been changed.
Thanks for the feedback guys greatly appreciate it
Now Im thinking, I could get new rockers and springs for these heads or should I go and get some GT40 heads and slap them on??
Old February 7th, 2011, 09:05 PM   #8
BULLET20XD's Avatar
I wouldnt worry about WHAT heads you have right now. Diagnose the knock. Pay attention to your oil pressure gauge. Mine got weak and on occasion would build then finally the knock go so bad it dropped to 0. I had the vcovers off i know eight times in 1 day and half. I was ready to go to the end of my driveway pull out on the road and set it on the limiter and scatter parts. Finally i got idea to pull it, tore it down and found the trouble.
1990 LX 5.0
2000 Expedition
2002 Honda Accord
Old February 7th, 2011, 09:16 PM   #9
BULLET20XD's Avatar
I will describe how mine started til i had to shut it down. Car developed a slight tick after i got the car. I run the car hard, running it into the rev limiter on occasion. The tick got worse, then i put stp in it. Quietened down some, oil pressure stayed low. Tick stayed away for about a day, then come back. I got on the car hard and that did it in. I was at school when it was hammering so bad, sounded like someone used a hammer on the valve covers. It was really bad. After school that night i was disqusted with the car and ready to let the bottom end see the real world. I didnt though, babied it home. Thast when i pulled it down. Im not saying pull the motor, use ur on decision. Like the other guys have said it can be a number of things.
1990 LX 5.0
2000 Expedition
2002 Honda Accord
Old February 7th, 2011, 10:06 PM   #10
ryanw's Avatar
1991 Ford Mustang GT
Ive never owned an e303 cam but im starting to think that cam keeps ford in buisness, no wonder they were the only ones that didnt have to file bankrupcy the e303 saved there ass.... Lol
Trick Flow R intake,
jba headers, 2 1/2" x pipe
flowmaster super 10 mufflers,
255 fuel pump,
3:27 gears
Old February 7th, 2011, 11:14 PM   #11
the heads havent been changed.
So should I check the rockers to see if they're damaged or something?
My cluster is reading that I have oil pressure.
Old February 8th, 2011, 10:55 AM   #12
VM0824's Avatar
1989 Mustang GT
~14@99 (b4 turbo)
if your rockers are still sittin tight on the pushrods then thats probably not it (probably), i cant think of anyway it would knock without the rockers having to be off the pushrods. at least for inside the valve cover.
if u can deal with the cleanup, maybe run the car without the valve covers. when i did it last didnt lose TOO much oil at idle, but if u hit the gas ur gonna see some oil fountains....was on a chevy 350 tho...
306 w/ 8.9:1
arp chromoly studs
lowered. sfc. HID
battery reloc
Old February 8th, 2011, 06:10 PM   #13
seems like cheap way of doing it...I'll give it a shot
Old February 8th, 2011, 06:13 PM   #14
Smirnoff's Avatar
1982 GT t-top
no proof of purchase
Smirnoff is on a distinguished road
i wouldnt trust the stock guage
LinkBack to this Thread: http://www.moddedmustangs.com/forums/5-0-mustangs/203146-91gt-knocking-noise-under-valvecovers.html
Thread knocking/ticking noise? | Forums at Modded Mustangs | BoardReader This thread Refback December 11th, 2011 12:10 AM
Threads Similar to: 91GT knocking noise under Valvecovers
Knocking noise/ticking hogster 2005 - 2010 6 July 28th, 2010 10:13 PM
Knocking noise. Stang808 V6 Mustangs 4 September 16th, 2009 09:46 AM
Ticking/knocking noise centuryt 99-04 8 July 25th, 2009 04:02 PM
Knocking/Click Noise jsando1 99-04 2 November 3rd, 2008 09:21 AM
Knocking noise on my 2002 zimalatina V6 Mustangs 11 September 23rd, 2007 08:20 PM
