Help with a supercharged 302 combo? - Page 4
Old February 25th, 2011, 08:45 PM   #61
Uber88GT's Avatar
1988 Mustang GT
Uber88GT is on a distinguished road
I love my s/c...but don't be scared to try it, it's nothing you can't figure out other than the tune...which is a whole other story...
Old February 25th, 2011, 08:51 PM   #62
Cloud Nine's Avatar
1990 Mustang
Cloud Nine is on a distinguished road
Yeah man I am getting a quarterhorse from a guy on ebay who includes email tunes and his support if I need help. His company is dirtydirtyracing.
Crossing my fingers this goes well. hehe
But shit dude, I was just looking at welders at home depot right now. They're only 250-300 for a MIG welder. I'm guessing these cheap ones are good enough for welding if I were to go turbo. Hmmmm
Are those electric welders good?
Old February 25th, 2011, 08:58 PM   #63
Uber88GT's Avatar
1988 Mustang GT
I have a MIG that I bought for $500, works great, my buddy has the same one that he built a complete home made setup..the piping is thin so it works well, just buy some pipe and practice because you don't want to fix a blown-through hole on your good pipe...if you even have to weld anything...
Old February 25th, 2011, 09:04 PM   #64
Cloud Nine's Avatar
1990 Mustang
How does this MIG look?
Lincoln Electric Century 80GL Wire Feed Welder - K2501-1 at The Home Depot
Not sure what GL strength is needed to weld turbo piping?
Old February 25th, 2011, 09:09 PM   #65
Uber88GT's Avatar
1988 Mustang GT
80 amps is a little on the low side if you ever want to do anything else other than thin wall pipe, if you can afford something in the 100+ amps range it would be more versatile, like for welding subframe connectors...it's all about penetration!!
Old February 25th, 2011, 09:18 PM   #66
Cloud Nine's Avatar
1990 Mustang
Haha alright. Do you think I would be able to weld in full length subframe connectors myself? The one where you weld it through the car. Is it any hard?
Old February 25th, 2011, 11:05 PM   #67
Uber88GT's Avatar
1988 Mustang GT
Why not? I'm welding my own in, but have a fair bit of welding experience. Its all about your confidence....
Old February 25th, 2011, 11:06 PM   #68
1992 Lx
11.39@119.24
you have to do it on a drive on lift, car has to have the weight on the wheels or itll fuck your car up, just a heads up
Old February 25th, 2011, 11:25 PM   #69
fogged306's Avatar
89 GT
That welder will get the job done, but expect to do some grinding on the welds because it's a flux core welder and you're an amateur. Flux core welders are tough to make pretty welds, but they work. If you get a gas MIG you can make pretty welds in a matter of minutes.. it's all about making little circles with the weld puddle.
Old February 25th, 2011, 11:47 PM   #70
ryanw's Avatar
1991 Ford Mustang GT
so you cant have it on four jack stands ? one under each A arm and one on each side of the axel ????
Trick Flow R intake,
jba headers, 2 1/2" x pipe
flowmaster super 10 mufflers,
255 fuel pump,
3:27 gears
Old February 25th, 2011, 11:52 PM   #71
fogged306's Avatar
89 GT
As long as the suspension is loaded you're fine. You just cant have any jackstands on frame points ect..
Old February 25th, 2011, 11:53 PM   #72
ryanw's Avatar
Good to know. thanks
255 fuel pump,
3:27 gears
Old February 26th, 2011, 12:04 AM   #73
Cloud Nine's Avatar
1990 Mustang
Thanks for the advice hatch. Yeah we got several lifts at my college.
I had another question. Do you need a bar map sensor for a supercharger or a turbo with a quarterhorse?
I only plan on running 8-10 psi at the most.
Threads Similar to: Help with a supercharged 302 combo?
Best CAI combo StutteringStang06 2005 - 2010 25 September 3rd, 2009 09:45 AM
Need Combo Help 1BADSTANG 5.0 Mustangs 15 March 31st, 2008 12:51 PM
How does this combo run fasta$$306 5.0 Mustangs 2 July 26th, 2007 01:56 AM
What Does My Combo Need? 82GT 5.0 Mustangs 18 November 16th, 2006 07:56 AM
