1989 Mustang LX 5.0
slow..help
control arm ?
so a couple months ago i took the cheap route and just replaced the ball joint on the driver side front control arm, and it solved the clunking noise/creaking problem for the time being.. now it seems to be acting up but on the passenger side. so i'm just going to order new control arms from somewhere online... anybody have any recomendations on which brand is better then another?
1989 Mustang LX 5.0
slow..help
17 views and nobody has any suggestions? comeon now.
If you want a really good set..
1979-93 Mustang Front Mild Steel Tubular Control Arms With Spring Cups at LRS - Same Day Shipping! Most others I have seen require the coil over kit. |
#4 | |
#5 | |
1989 Mustang LX 5.0
slow..help
Take an adjustable wrench and adjust it to fit the sway bars thickness. Measure the distance of the wrench. I think there may be like 4 different sizes.
The Big Spoon
88 5.0 5 Speed Notch <><
never fast enough
I bought the ford racing upgraded units for around 300 right from the ford stealership. I had a problem with whose replacement parts I used. AZ ball joints kept making noise so I said eff it and installed brand new shizz.
#8 | |
The Big Spoon
never fast enough
use 6 1/8 overall length for stock ride height and 5 3/8 for cars lowered greater than 1 1/2 inches. I imagine that their meaning of over all length is the distance form where the sway bar sits in the end link to where the control arm sits in the end link. If you are stock go for the 4' spacer. If you are low, go for the 2.5 inch spacer. edit:http://www.energysuspensionparts.com...-End-Links.asp
Black Stang Crew Last edited by jessemachone; February 14th, 2011 at 04:54 AM. |
Threads Similar to: control arm ?
| Best rear lower control arms? need control.. | Speeddemon | 94-95 | 6 | April 19th, 2010 02:55 AM |
| steel control arms vs aluminum control arms | Saleenwolf720 | 99-04 | 1 | October 15th, 2007 01:32 PM |
| Upper Control Arms & Lower Control Arms | LUV2XLR8 | 2005 - 2010 | 6 | October 6th, 2007 11:45 AM |
| Code P1443 Evaporative Emmision Control System Control Valve | jagstang96 | 96-98 | 10 | September 5th, 2006 07:26 PM |
| Purge Control Solenoid or Purge Control Valve fault | kdevildog01 | General Tech | 3 | July 17th, 2006 01:45 PM |
