stumbling 5.0
The symptoms. When accelerating my 93 5.0 will stumble and hesitate also the tach sticks and bounces at about 2500 rpm when this happens. The car idles fine and once you let off the gas and maintain an even speed it runs smoothly.
Things Ive tried to fix it. Swapped coil, ignition module on distributor, swapped 02 sensors, cap and rotor, checked tps voltage and timing on distributor, disconnected msd spark box. No I didn't buy all that stuff! Any ideas what I might try next? Thanks in advance for any help. |
1992 mustang Lx
13.4@ 106
Have you checked your fuel pressure? I'd check that to see what it looks like. I don't know about the tach. Could also be the maf. My old 95 had those problems minus the tach thing when the maf went bad. It could also be many other things.
![]() 1992 5.0 lx_soon to be powered by a m122 GT500 supercharger
Thanks for the reply. I don't have a fuel pressure gauge but i did run codes and did not get any thing related to the maf. all the codes I gat were related to to missing emissions components. I s there another way to test the maf?
1992 mustang lx 5.0
mine was doing the exact same thing awhile ago and i just had to replace the plug wires...
However, I thank you, for this pen and ink ammunition.. Thank you for the inspiration! |
1992 mustang Lx
13.4@ 106
Check for vacuum leaks. You can then clean the maf to make sure it isn't dirty. Then check this out. You can test with a voltmeter.
Part 1 -The Basics of Testing the MAF Sensor
Thanks for the help mightyjo. Gonna try the maf test monday when I get a chance. Iam little leery of piercing the wires so i might try and swap it with a friends first to see if that cures it.
Turned out to be the spark plug on number 2 cylinder. There were 2 hairline cracks on the white part ( the insulator?) . Runs great now!
1992 mustang lx 5.0
right on!
1992 mustang Lx
13.4@ 106
glad to hear you fixed it!
Threads Similar to: stumbling 5.0
| stumbling up top | Blackblurr_00GT | 99-04 | 21 | February 18th, 2010 04:53 PM |
| Engine stumbling | Mando95 | 5.0 Mustangs | 7 | October 15th, 2009 02:40 PM |
| Stumbling on acceleration | lowp51 | 94-95 | 4 | March 14th, 2009 10:13 AM |
| stumbling prob- what i know so far | prinzzz | 2005 - 2010 | 2 | May 31st, 2008 02:01 AM |
| stumbling in | hawxter996 | V6 Mustangs | 20 | March 6th, 2007 09:51 PM |
