1990 Mustang
post your 302 11 sec combos
Post your 302 n/a or supercharged combos here
Thanks |
Pretty much any solid heads/cam/intake 5 liter falls into this category. The important part is making sure the rest of the car is set up correctly.
1969 Mustang Mach 1
6.824@101.61
Stock 302, 150 shot.
./___ _ ____ ___ \. ( ]]] _ _ O _ _ [[[ ) \_ o _ _____ _ o _/ |___| ......... |___| http://www.youtube.com/watch?v=HyYU3...e_gdata_player |
1989 Mustang GT 5.0
^ i like
Cage Maximum Motorsports Sparco QH/BE Nitto "a huge bad azz motor is nice untill you have to turn or stop" |
1990 Mustang
I don't really feel like running nitrous mainly because there is no real tuner where I live and I'll end up doing the tuning with a quarterhorse.
Unsure if tuning nitrous with a quarterhorse is gonna be too hard. And I don't really wanna fill up the bottle over and over so thats why I rather do it with a blower, but preferably n/a. |
1992 Mustang LX
13.0 @ 105
TFS 170 heads
TFS stage 1 cam Victor 5.0 EFI Intake All supporting bolt ons, MAF, TB full exhaust, injectors etc.
As I lay rubber down the street I pray for traction I can keep But if I spin, and begin to slide Please dear God, protect my ride |
1990 Mustang
Would I need to upgrade fuel lines and fuel rails for a 302 that hits 11 sec.?
No.
1991 GT, full weight, A/C, P/S and all other factory accessories.
302, Twisted Wedge heads, Trick Flow 51402001 cam (if I remember correctly), Trick Flow R-series intake, 75mm throttle body, Pro-M 77mm maf and all the common bolt ons. Thru a 5 speed and 3.55 gears it went 11.59 @ 114mph on a 26x8.5 slick.
#10 | |
1990 Mustang
1990 Mustang
Oh yeah will I need to run these pistons if I get trick flow heads on a 302?
Trick Flow Specialties TFS-51404000 - Trick Flow® Forged Pistons - Overview - SummitRacing.com Can I still use stock rods and crank? |
The entire bottom end of the 5.0 is reliable. I heard they dont break down till after 9k rpms. and like 800 hp. The pistons are forged, not sure about the rods and crank.
1990 Mustang
Would I need to upgrade my fuel lines rails if I were to put on a vortech v3 supercharger pullied to 10lbs of boost on stock motor?
I heard you only need to get a bigger diameter supply line, aftermarket fuel rails, and a 255 fuel pump? Is this true? |
#14 | ||
1991 Mustang LX 5.0
My buddy is still on stock rails and lines with his supercharged 342. He's got a 255 in tank and a t-rex boost a pump. It's not ideal, and needs to be upgraded, but he put down 475rwhp through a 4k stall. Tuner said to upgrade fuel system also.
Point made in less than a few hours with minimal response. http://www.moddedmustangs.com/forums...ml#post4465184 |
#15 | |
1990 Mustang
Does anyone if those pistons are balanced? I couldn't tell by looking on summit.
Can I use my stock rods and crank with those pistons? Do I need to get them re-balanced? |
You balance the rotating assembly together, not piece by piece.
You balance the rotating assembly together, not piece by piece. Yes you can use your stock rods and crank.
#19 | |
my soon to be 11sec combo is port tws 60x/59x 32x/33x 112lsa ported victor 5.0 efi 1 7/8 kooks headers 3.73s team z rear suspension |
It was a joke after the whole clubhouse thread. I left it up because its getting a shit load of hits and there has been like $15 donated. Lol! Everyone feels sorry for a picture of a guy that needs beer, pot and a hooker.
Threads Similar to: post your 302 11 sec combos
| engine combos | 83mustman | 5.0 Mustangs | 3 | January 19th, 2011 09:30 PM |
| Body kit combos | norcalam2 | 99-04 | 45 | December 23rd, 2009 10:10 PM |
| 351 combos | Nitrous Injected | 5.0 Mustangs | 5 | June 12th, 2009 02:44 AM |
| good H/C/I combos | 5.0Madness | 5.0 Mustangs | 21 | June 5th, 2008 09:39 AM |
| Possible Combos | RandoGT | 96-98 | 11 | October 10th, 2007 08:14 PM |
