Why wont my car start?
Old February 11th, 2011, 08:01 PM   #1
mustangmaniac95's Avatar
1995 Mustang GT
mustangmaniac95 is on a distinguished road
My 95 gt hasnt started in about 2 weeks, i ordered the whole ignition kit:spark plugs, wires,coil,cap/rotor etc. and then i put it on today and the car still wont start, and my spark plug reader is showing very weak spark...what else could be causing it not to start, please respond quickly so i can get it started as soon as possible
95 GT: JLTcai, Flow40s, o/r Xpipe, lowering springs, cobra brakes, cobra rims, sbfc, shocks/struts, trickflow170 heads (1.6rr), cobra intake, custom cam, 75mm MAF, 75mmtb, bbk shorty headers, 24#injectors, 3.73 gears, mach 1 chin spoiler.
Old February 11th, 2011, 08:46 PM   #2
Ohsplat's Avatar
1983GT
No motor or trans
Ohsplat is on a distinguished road
Send a message via Yahoo to Ohsplat
Does that car have a module on the distributer? There are a few things that can cause weak spark, you replaced most but not all of them. You need to check voltage at the coil, make sure you have good spark at the coil, and if you search google theres a way to ohm test the module. I had a 5.0 tbird that had nice spark at the coil, but after the cap it dropped off massively. I checked each component I listed, and found the coil to be faulty. It would produce a hot spark, but not enough to go thru the gaps in the dist cap. Hope this helps.
Old February 11th, 2011, 09:13 PM   #3
1995 Mustang GT
yeah we checked the fuel and its good, so not the fuel pump..and we test the spark at the coil and it has a weak one..and then i called my uncle because he had this exact problem on his 5.0 f250 a few years back and hhis was the ignition module so we are gonna check that and hopefully thats what it is..thank you for the help, if the ignition module doesnt work its most likely what you suggested
Old February 11th, 2011, 09:17 PM   #4
1slo5.0's Avatar
1990 Mustang LX
9.36@143 mph
Just out of curiousity, how did you check the fuel? An EFI car is very specific with its requirements on fuel pressure. If you did not use a gauge to check fuel pressure then you don't know if it is good or not.
Common ignition problems on these cars is the PIP in the distributor and the ignition module.
Old February 11th, 2011, 09:22 PM   #5
1995 Mustang GT
im not really sure, my dad checked it idk with what tho, and he said it read 30psi which is what it needs
Old February 11th, 2011, 09:35 PM   #6
Ohsplat's Avatar
1983GT
No motor or trans
Did I miss a post? I didnt even see anyone suggest checking the fuel. Ignition modules tend to go bad from heat. You can prolong their life by putting some Dielectric grease everywhere it touches. I would have replaced the coil 1st, heck I think you can get one for 15$ and if it dont solve the problem take it back and get the module. I know I HATE autozone, but get a coil there and just hook it up without mounting it. See if that solves your problem. If not you can say you replaced the module 1st and didnt need the coil.
Old February 11th, 2011, 09:43 PM   #7
1995 Mustang GT
we have already replace the coil and the plug wires and new spark plugs today..and was looking at a new ignition module and they are around $60-70 and i like oreillys better lol, but so are you saying to put dielectric grease on the ignition module or the coil?
Old February 11th, 2011, 09:45 PM   #8
Ohsplat's Avatar
1983GT
No motor or trans
On the module. Most of them come with it. Put it on the connections.. not the plastic lol. If it has a solid steel plate where it connects to the dist, put some there as well. Dont use so much that the grease causes the connections to touch. Sorry I didnt see you said you replaced the coil. Its gatta be your module. If not you may be looking at a new ecm.
Old February 11th, 2011, 09:48 PM   #9
1995 Mustang GT
i was just researching the ignition module and looks like that is whats wrong with it, but i am going to buy the pip on the distributor and the ignition module...do you know where the ignition module is located? and if so, can you show me a picture
Old February 11th, 2011, 10:00 PM   #10
Ohsplat's Avatar
1983GT
No motor or trans
Its usually gray in color and has a harness connected to it. Its below the dist cap and before the dist shaft. It sticks out usually pointing toward the pulleys.
Heres a link.
Ignition Control Module | 1995 Ford Mustang 8 Cylinders T 5.0L SFI HO | AutoZone.com
http://www.autozone.com/autozone/cat...00&parentId=29
Old February 11th, 2011, 10:06 PM   #11
1995 Mustang GT
thank you, helps me out a lot...would you also happen to know where the pip is? i know its on the distirbutor but anything that makes it stick out
Old February 11th, 2011, 10:33 PM   #12
Ohsplat's Avatar
1983GT
No motor or trans
I have no Idea what a PIP is on a dist. Are you talking about the pickup coil? If so it is inside the distrib and you have to remove it to replace it. If you are going to go thru replacing that and the module, you should just get a remanufactured dist that has a new pickup and module.
Old February 11th, 2011, 11:02 PM   #13
1995 Mustang GT
its the profile ignition pickup and it says its under the distributor i think but not sure...my dad said we are just gonna replace both the ignition module and pip at the same time to get it over with
Old February 12th, 2011, 12:08 AM   #14
Ohsplat's Avatar
1983GT
No motor or trans
i think he means the pickup. In that case just get a reman dist.
Old February 12th, 2011, 01:52 AM   #15
fogged306's Avatar
89 GT
Hows your grounds look?
Old February 12th, 2011, 05:37 AM   #16
1990 gt 2006 gt
.99@14mph
ahduckit is an unknown quantity at this point
The TFI module isn't under the distributer on the 94 or 95. Its located on the passenger side fender well under the air box assembly if I remember right. Been a while since I sold my 95.
Old February 12th, 2011, 09:00 AM   #17
Ohsplat's Avatar
1983GT
No motor or trans
Not from the diagram that shows up in autozones web site. They show it being the same one in the 79-93. I believe you are thinking about the mod engine.
Old February 12th, 2011, 09:47 AM   #18
1995 Mustang GT
i forgot which website i was reading from but it said from 87-present on the fords, the ignition module is on the distributor
Old February 12th, 2011, 10:19 AM   #19
1slo5.0's Avatar
1990 Mustang LX
9.36@143 mph
You are correct. In 1994 Ford moved it to the fender well on the Mustangs just like the trucks to get it away from engine heat.
Old February 12th, 2011, 10:46 PM   #20
1995 Mustang GT
yep the ignition module was on the passenger fenderwall, and i replaced it but it didnt help..will replace the pip in the distributor probly next weekend...but after we put the new module in and didnt work we put the old one back on and the car cranked up perfectly just had to jump it first..but now about 5 hrs later i went to start it up and the thing still wont start..idk what to do now, i need the car so i can drive to school and work..could it be a grounding problem? if so how can i test it and fix it?
Threads Similar to: Why wont my car start?
96 Wont Start MeanGreen 96-98 2 September 21st, 2010 04:21 AM
wont start 50GT23 5.0 Mustangs 18 May 3rd, 2010 04:10 PM
My car wont start 00mustangv6 V6 Mustangs 4 October 8th, 2009 05:27 PM
car wont start 1BADSTANG 5.0 Mustangs 12 January 14th, 2008 01:01 AM
