1993 Mustang LX
my dog runs faster...
Who's got nitrous?
Thinking about a nitrous kit. Give me your opinions. Prefer one kit over another, wet/dry, whatever. Who's had problems with hypereutectic pistons and nitrous? I was thinking 100-150 shot.
![]() MM+Cleavage Club Member #19
Get the NOS 05115-ii dry kit. It is adjustable up to 150hp or so. It is the best low hp nitrous kit on the market for Mustangs. Quality parts, good instructions and easy to install if you have some mechanical ability.
Hypereutectic are fine with 150hp of nitrous.
'89 LX 'Vert
10's or bust... Literally.
I love my NX products.
100 wet shot all day and night, no issues, just drop timing 2-4 degrees. im going to be using a 150shot on my new short block that has explorer hyper pistons. as long as you don't let the car go lean you will be alright.
H/C/I 302 + nitrous for now... supercharger/turbo soon? ![]() |
1993 Mustang LX
Can you get away with a basically stock fuel system with either kit?
Yup...stock fuel system is fine. I have a zex wet. The jets are under-rated but you just go up a jet. Buy a window switch
Black and White Crew ![]() Crew Member # 3 centerforce dual friction,.100 shot freeflow exhaust,70mm accufab tb,professional products plenum, tri ax,3.90s amazing how fast you can go when the road never curves .....lighting up the Canadian prairie |
1992 Mustang LX
13.0 @ 105
Upgrade injectors and fuel pump if you want to shoot 150.
As I lay rubber down the street I pray for traction I can keep But if I spin, and begin to slide Please dear God, protect my ride |
1993 Mustang LX
24lb's? How big would you have to go on fuel pump..190lph or 255?
The zex wet systems work off the TPS wich is much easier to use. It only sprays at WOT and you can set the min rps for it to spray as well.
How do you set rpms without window switch. If you can tell me I guess I got a window switch for sale
The wet kit I saw from them comes with the window switch.
'89 LX 'Vert
I would recommend a bigger fuel pump, but you don't really need anything else. (change out your fuel filter, run 91-93 octane.) if your going to run 150 shot, get a step colder plugs.
if your using a wet kit, there is no need at all for bigger injectors. bigger injectors are for dry kits that spike fuel pressure when the nitrous comes in. NX sizes there jets pretty good, but very fat, as in a little to much fuel. What I do is use there recomindations, and just bump bottle pressure to 1000-1100, or if I get the car on the dyno, I will play with jet size while watching air/fuel ratio, that was you don't have to wait for 10-20min for the bottle to get warm enough.
#12 | ||
Yes, but I would replace the fuel pump for two reasons. The stock fuel pump is barely adequate for the stock engine and chances are it is old and tired.
No need to upgrade injectors. Go with a 255lph right away. Its not much more than a 190lph.
'89 LX 'Vert
I agree, but I also think when its spiking fuel pressure I wouldn't trust stock 19pound'ers to not rupture a ring or something and start leaking after some abuse.
1993 Mustang LX
I suppose the only way to check your fuel pump is to pull it out, right? When I bought the car, he said it had a 255...but he was also a dumbass.
For some reason, I'm drawn to the ZEX kits ... Zex Wet Injected Nitrous System (86-04 V8) at AmericanMuscle.com - Free Shipping!
#15 | ||
1993 Mustang LX
Price is always a factor, but really because I like the color of the parts :-) I don't want to just go out and buy a cheap one, so I'll check them all out first. My buddy was really happy with NX so maybe ill go that route.
1992 Mustang LX
13.0 @ 105
A local nitrous tuner of mine recommends an Edelbrock or an N.O.S kit for the stock mustangs he tunes.
1991 Mustang LX 5.0
I'm using a NX intake plate setup this spring. Supposedly the shit, but I couldn't tell ya yet.
Point made in less than a few hours with minimal response. http://www.moddedmustangs.com/forums...ml#post4465184 |
'89 LX 'Vert
+1
ill be getting a plate for my typhoon intake more then likely. but I might go for a super victor with an elbow so I can run a carb plate instead of the high dollar efi plate. will pick up some power on motor, and save me a ton for the nitrous plate.
'02 VERT
13.08@106.11
I just got my nx plate shot yesterday for the Vic jr .. Sold my ZEX kit but It only came with the 150 jets does anyone know what jets I need for the 100 shot not worried about putting it in just yet I got to fix my lean issue...
CMS STAGE II FRPP 4.10s LTS, O/R H, FLOWMASTER WELD ONS EDELBROCK INTAKE MHS 6061 ELBOW NX PLATE 100 SHOT SCT X3 TUNED BY JOE MANSFIELD AT ABOVE AND BEYOND PERFORMANCE |
Threads Similar to: Who's got nitrous?
| nitrous | capecodstang | 99-04 | 3 | September 17th, 2010 01:09 AM |
| Nitrous | GTRumble | 99-04 | 31 | September 14th, 2010 12:05 PM |
| Getting Nitrous and new clutch installed...have a question about nitrous | VanWilder | 2005 - 2010 | 2 | May 13th, 2010 11:52 AM |
| Nitrous help (what do I need) | twok3gt | 99-04 | 4 | October 20th, 2007 08:52 AM |
