Power steering whine - Page 2
Old February 13th, 2011, 09:45 AM   #21
1989 Mustang GT
Black89gt is on a distinguished road
Small thing to watch for is when you 1st install it, make sure you fill, crank car, only 5ish seconds, and turn off, if you dont put in enough on install & leave running for it to get dry, itll whine everytime, and use Type F Transmission fluid w/ Lucas.
Old February 13th, 2011, 09:58 AM   #22
orangestang42's Avatar
1995 Mustang GT
orangestang42 is on a distinguished road
well im gonna see if i can get my hands on one from ford then
Old February 13th, 2011, 10:25 AM   #23
AdderMk2 will become famous soon enough
Send a message via AIM to AdderMk2
When I put my new pump on, I filled the reservoir and spun the pulley by hand. when it got low, I topped it off and kept going. I did this for maybe 15 minutes until the air bubbles stopped. then cranked the car and turned the wheel lock to lock while checking and filling.
I get no noises at all from my pump.
[URL="http://providence.craigslist.org/cto/2148862880.html"]1994 Cobra For Sale[/URL]
[SIGPIC][/SIGPIC]
[QUOTE=Timm10221]Its only a 10 inch Tach that sits right in the center of the dash with LED lights and a Spinner bezel that has dimonds and gold plating.. And when you hit 4500 plus is sounds off (AAHHH SHITT) :cool:[/QUOTE]
Old February 13th, 2011, 02:41 PM   #24
87superduperstang is on a distinguished road
My pump whines a little to but im married so im use to whining my wife does 24-7
Old February 13th, 2011, 02:44 PM   #25
the secret lies in the type of fluid you use............ if you research on some ford websites like corral.net you'll find the answer
Old February 13th, 2011, 06:30 PM   #26
The Big Spoon
jessemachone's Avatar
88 5.0 5 Speed Notch <><
never fast enough
jessemachone is a glorious beacon of lightjessemachone is a glorious beacon of lightjessemachone is a glorious beacon of lightjessemachone is a glorious beacon of lightjessemachone is a glorious beacon of light
waste of money.
Black Stang Crew
Originally Posted by 302Army187 View Post
old 5.0's are like a box of chocolates.......... never know what your gonna get
Old February 13th, 2011, 06:41 PM   #27
The Big Spoon
never fast enough
super tech - that is what I have in it and I have 0 whine
Black Stang Crew
Old February 13th, 2011, 06:43 PM   #28
The Big Spoon
never fast enough
LOL - maybe you married the wrong woman or you aren't quite cutting it as a husband. Give her a super tech enema!!!
Black Stang Crew
Old February 13th, 2011, 10:44 PM   #29
1995 Mustang GT
ok guys, well i think i may have foudn the problem, after replacing the pump with one from auto zone i sat there for like 15 minutes and just turned the steering wheel from side to side and it started to quiet down quite a bit and then it wasnt really noticeable anymore, well then i went out to dinner for valentines day and little did i know the pressure hose was resting on the side of the power steering pulley and eventually rubbed a hole in it and power steering fluid went everywhere and now its sitting in the driveway waiting till tomorrow until i get a new pressure hose, ugghh just my luck. Do you guys think i did any damage to the new pump? it wasnt making any weird noises and i had to drive it about a mile to get it back home. but that bitch was hard as hell to turn lol. I think it was still pumping some of whatever fluid was left in it
Old February 13th, 2011, 10:50 PM   #30
The Big Spoon
never fast enough
No way to know 'till after it is fixed. Jack that thing up real nice and high when you replace that line. I had a bear of a time getting the threads to start. I think I would have had a much better time of it if the car was up on jack stanfs.
Black Stang Crew
Old February 14th, 2011, 03:22 PM   #31
1995 Mustang GT
ALL FIXED!!
and hardly makes a sound, the hose went on easier than i thought it would
the MOST IMPORTANT THING, air in the lines..it really doesnt matter what ps pump you buy the air trapped in these lines and pumps is a pain in the ass to get out. If you bleed it the right way you should have no problems
this is what i did. I filled the fluid up then started the car, added a touch more fluid and then reached in through the window and turned the wheel to one side until if fully locked and then i held it there, you will hear an unsettling noise, this is ok. With your hood up and power steering cap off you should see a bunch of little bubbles coming to the top, this is the air in the lines, as soon as you have held it there for a minute or two turn it to the other side and repeat, do this until it quiets down to where it should be, this was a 15 minute job for me, so take the time and make sure you bleed it all out and then put the cap back on and your done... let me know how you guys make out
Old February 14th, 2011, 07:38 PM   #32
Ohsplat's Avatar
1983GT
No motor or trans
Ohsplat is on a distinguished road
Send a message via Yahoo to Ohsplat
i was gonna recommend NOT turning the wheel when the car is still. You probably also have much larger tires then stock on the front and are stressing the pump in the 1st place. When I got my car it had 205 15s and had no whine. Now I have 255 16s and it whines a lot.
Old February 15th, 2011, 12:11 AM   #33
1995 Mustang GT
well i spoke too soon i guess, i burnt up the pump driving it home after i blew the line, you can hear it buzzing inside the car, well i am tired of changing out this damn pump, hopefully this will be the last time, on a good note though i think i should enter the guiness book of world records for the fastest in changing out this pump because im getting pretty damn good at it, lol..
Old February 15th, 2011, 10:43 AM   #34
Will6138's Avatar
1988 GT MAF
Will6138 is on a distinguished road
Mine whines but I run wider tires and have an underdriven pulley on the pump. Pump is brbrand new aand still whines, my last stang did it as well.
Old February 15th, 2011, 02:07 PM   #35
1995 Mustang GT
yeah i realized what ohsplat said about the tires, as a matter of fact i have 255's on the front so that could be whats contributing to the wine a little, but they are running out of tread so im prolly gonna bump back down to a 245 on the front and leave my 275 on the back
Old February 15th, 2011, 03:00 PM   #36
EscortSportage's Avatar
1989 Mustang GT 5.0
Maximum Motorsports sells thier own PS pump...its really expensive but, its lighter/and uses less power to spin and has better feedback
Cage
Maximum Motorsports
Sparco
QH/BE
Nitto
"a huge bad azz motor is nice untill you have to turn or stop"
Old February 15th, 2011, 03:02 PM   #37
1989 Mustang GT 5.0
how do u blow a ps pump? ive never had any problems with mine, u need to start running higher grade PS fluid, with a boiling point of 500 degrees,
Cage
Maximum Motorsports
Sparco
QH/BE
Nitto
Old February 15th, 2011, 04:41 PM   #38
1995 Mustang GT
the pressure line somehow got close to the ps pulley and put a hole in it, which in turn fried the pump because i had to drive it back home, i thought it would be ok but its not.... ^^
Threads Similar to: Power steering whine
How to fix the power steering pump whine? sk_idLA V6 Mustangs 23 January 26th, 2012 11:15 AM
Help with power steering to manual steering conversion Alucard2008 94-95 3 April 20th, 2011 06:12 AM
power steering to manual steering swap necro5.0 5.0 Mustangs 14 March 25th, 2010 10:57 PM
steering whine Stang187 V6 Mustangs 13 May 7th, 2009 10:42 AM
Decreasing power steering pump pressure for tighter steering 83 5.0 5.0 Mustangs 6 January 7th, 2007 08:24 PM
