1995 Mustang GT
Power steering whine
another issue that is seriously pissing me off.. i am on my second remanufactured pump and the pump whines when you turn the wheel standing still...i have a brand new rack, high pressure line and pump..what the hell is the problem, its annoying and i have tried everything i can think of
1991 Mustang GT
Sloowwwww
I seem to be having the same problem as well.
Black 'Stang Crew #1337 |
2003 Mustang Mach I
fluid??
1995 Mustang GT
no bro, that isnt it...flushed it, replaced the pump and filled with the proper fluid and it still makes noise..
2003 Mustang Mach I
maybe it needs more even after you filled it up. cuz it is a new pump
2003 Mustang Mach I
doucle check now
and check this out actually some useful stuff Answers.com - Why would the power steering make noise even after fluid has been added |
1995 Mustang GT
dude, the thing is full, i filled it up and looked again and its all the way to the top, and thats an interesting answer on that website, i was deciding on wether to buy a pump straight from ford but they wouldnt be able to get one till tuesday of next week and i kind of needed it before then. so maybe here in another week or 2 i will suck it up and buy a FORD power steering pump from the dealer
91 GT 90 LX 5.0
I have the same noise on my '90 hatch and its really bad on my '95 exploder but the power steering works fine so i just deal with it
1991 GT- All Stock 1990 LX 5.0- CAI, Shorty headers, flowmaster, Tubular Upper and Lower Control arms, Tokico HP series, Eibach Springs |
1991 Ford Mustang GT
fords have nosie power steering pumps, how nosie is it ?
1995 Mustang GT
its hard to hear inside the car, but its noticeable outside the car, its not really loud but loud enough to where u can hear it over my exhaust
91 gt
autozone has an additive that works pretty good. i put it in my 91 an it quieted it up alot. its called something power steering fix.
1995 Mustang GT
yeah i put in the lucas power steering conditioner, if thats what your talking about?? it quieted it down a little but its still noticeable, i have heard of people buying direct for replacement pumps and getting rid of the noise completely
2003 Mustang Mach I
call that guy from ft myers see if he has one
1995 Mustang GT
its not gonna do me any good man..lol, i just swapped in another new re-manufactured pump and its doin the same thing, it doesnt matter what pump i put in, only one i havent tried is a pump from ford
91 GT 90 LX 5.0
The guy i bought the explorer form said he switch the pump out one time becuase it was making noise and it fixed it for a while then he said it started back up, its very lound on my explorer and ive added additive as well, im not that concerned as long as the ps works. The mustang on the other hand if possible i wouldnt mind finding a relatively easy/cheap way to fix it. Maybe ill try an additive sometime
The Big Spoon
88 5.0 5 Speed Notch <><
never fast enough
it is because it is a ford.
I replaced mine with a unit from autozne and it is doing well. I think once you run them low, they burn and make that noise until you replace it. I got one from autozone because of the life time warranty. When it makes noise again, and I'm sure it will, I'll just exchange it for a new one. |
91 GT 90 LX 5.0
well if i ever run into any trouble with mine thats definitely what ill do, plus lifetime warranty is very nice
1995 Mustang GT
hmm so do you think i should try auto zone then...the two that i have tried now are from advance auto? and DAP noticed u were from youngstown, i grew up in Lisbon not too far from there
also, would the fact that the car is lowered have anything to do with the power steering pump? Last edited by orangestang42; February 13th, 2011 at 02:14 AM. |
The Big Spoon
never fast enough
when I got mine from az, there was a tag on it advising me of a whine that is normal. It whine for a little while till I got some miles on it. It was nothing like the whine of the unit that it replaced.
If you dont want to hear the whining, convert to manual steering or buy something other than a 80-s to 90's Ford.
staying away from remanufactured pumps is a good thing to do as well.
[URL="http://providence.craigslist.org/cto/2148862880.html"]1994 Cobra For Sale[/URL] [SIGPIC][/SIGPIC] [QUOTE=Timm10221]Its only a 10 inch Tach that sits right in the center of the dash with LED lights and a Spinner bezel that has dimonds and gold plating.. And when you hit 4500 plus is sounds off (AAHHH SHITT) :cool:[/QUOTE] |
Threads Similar to: Power steering whine
| How to fix the power steering pump whine? | sk_idLA | V6 Mustangs | 23 | January 26th, 2012 11:15 AM |
| Help with power steering to manual steering conversion | Alucard2008 | 94-95 | 3 | April 20th, 2011 06:12 AM |
| power steering to manual steering swap | necro5.0 | 5.0 Mustangs | 14 | March 25th, 2010 10:57 PM |
| steering whine | Stang187 | V6 Mustangs | 13 | May 7th, 2009 10:42 AM |
| Decreasing power steering pump pressure for tighter steering | 83 5.0 | 5.0 Mustangs | 6 | January 7th, 2007 08:24 PM |
