#1 | ||
88Notch 10.59 @132 / 03 Mach 1 13.1 @104
Went to the Track Today
So went to the track and was able to get 2 runs in. Both 13.0 at 108ish.. This is also with the stock tired tranny and launching at around 1200rpm do to the stock converter.. I know I know...
So the issue, Happened to me twice now, The car is having some trouble turning over. I went to the track and parked her, went to start and no go, tried to jump start with a cummins diesel, nope. so went and got a new battery "Red Top" and still have a hard time starting but finally did. Also after that start, the guages all tached out, ie the temp and oil pressure went all the way to the right.... So I knew this wasnt the true reading and ran my 2 passes not turning the car off and went home, Then I pulled the previous owners hack job of a security / remote start install and made sure all my grounds are good, put the battery back in the engine back and still has a hard time turning over. It sounds like there is a huge drop in amps getting to the starter.. it doesnt click or anything like that, has a new starter, new battery, all grounds are good, the only thing left that I think it could be is the power to the starter.. the starter cable its self.. It is the original, and it green with corrosion... so I just ordered a new one from summit for like 30 bucks since no store around here has one long enough and hope that fixes it... If you have any ideas besides that please let me know.... 93hatch, she feels strong dude!! I can't wait to get back from this pump and do the c4 with a high stall and do a 150 shot... oh yeah! Tim
Military Crew USMC
#2 | ||
Oh I know when the gauges tach out like that, it indicates a short somewhere... I am trying to figure out where, that's why I started ripping out all the old security / remote start shit I don't use, that the previous owner did. I wanted to eliminate that hack job outa the equation lol
Military Crew USMC
1995 Mustang GT
Is the car doing this off of a cold start as well? If it is only doing it after the car is hot and you are going for a restart, it almost sounds like the starter is heat soaking.
This of course doesn't explain the gauge spike you are talking about, so I may be completely off base. I had the hard turn over issue when my car was hot though, replaced the starter and wrapped it with a versashield from summitt and haven't had an issue since. |
#4 | ||
Humm, I will have to see, But It sat in the garage while I was redoing the ignition wiring for 2-3 hours then I trying to start it and got the same issue.. And its a new starter.. If replacing the power cable to the starter doesn't fix it then I will be at a loss lol. I will have to keep this in mind though, Thanks!
Military Crew USMC
Was it a quality starter?
'89 LX 'Vert
10's or bust... Literally.
I think your hunch about that wire could be right.
I know you said you checked all the grounds, but the gauges wouldn't peg if the power cable was bad. they peg when they have a bad ground. so I would go over them once again. really hope you commit to that 150 shot and big stall. will get that puppy in the 10's if it hooks
H/C/I 302 + nitrous for now... supercharger/turbo soon? ![]() |
#7 | ||
Yeah, your right Army... I know the grounds in the engine bay are good, but I did forget to check the computer area and that ground there come to think of it. Im also going to pull the dash today and see whats going on with the wiring back there.
Military Crew USMC
'89 LX 'Vert
I hope you don't have to go as far as pulling the dash. I would look at the ground on the fenders, and motor first.
Idk about SN95's but on foxes your looking at the ground by the battery on the inner fender, and the ground on the timing cover on the drivers side....... as im sure your aware. then i would branch out to the starter, the ECM ground, and so on.
'89 LX 'Vert
and don't just look at the ground point and see if its tight, chase the wire as far as you can, could have broken apart or something.
1995 Mustang GT
![]() iTrader: 2 reviews
[QUOTE=Timm10221;3517637]
So the issue, Happened to me twice now, The car is having some trouble turning over. I went to the track and parked her, went to start and no go, tried to jump start with a cummins diesel, nope. so went and got a new battery "Red Top" and still have a hard time starting but finally did. Also after that start, the guages all tached out, ie the temp and oil pressure went all the way to the right.... So I knew this wasnt the true reading and ran my 2 passes not turning the car off and went home, Then I pulled the previous owners hack job of a security / remote start install and made sure all my grounds are good, put the battery back in the engine back and still has a hard time turning over. It sounds like there is a huge drop in amps getting to the starter.. it doesnt click or anything like that, has a new starter, new battery, all grounds are good, the only thing left that I think it could be is the power to the starter.. the starter cable its self.. It is the original, and it green with corrosion... so I just ordered a new one from summit for like 30 bucks since no store around here has one long enough and hope that fixes it... i am having this same problem with my 95..ive changed out the igniton module, and still same problem, may be the problem with yours...and ive had to jump my car twice, so maybe its the battery with mine...but with mine, i just changed the spark plugs and everything, and i have a weak spark, and ive been reading everything to figure it out but idk what it could be...if you figure out what yours is lemme know how you fixed it
95 GT: JLTcai, Flow40s, o/r Xpipe, lowering springs, cobra brakes, cobra rims, sbfc, shocks/struts, trickflow170 heads (1.6rr), cobra intake, custom cam, 75mm MAF, 75mmtb, bbk shorty headers, 24#injectors, 3.73 gears, mach 1 chin spoiler.
1992 Mustang LX
13.0 @ 105
Quick question, is this on street tires? And what does the car weigh?
As I lay rubber down the street I pray for traction I can keep But if I spin, and begin to slide Please dear God, protect my ride |
1992 Lx
11.39@119.24
bet you 50 bucks its a bad connection from the battery dude. Just replace both cables cheap insurance. And ewww c4 go built aod
#13 | ||
I have an AODE... So you think a Built AODE????
Military Crew USMC
#14 | ||
Oh and this is on 275/60/15 mickeys... car is around 3100 I would think...
Military Crew USMC
'89 LX 'Vert
1992 Lx
11.39@119.24
I just think no od is retarted dude. Cars that arent good to take on a good drive=fuggin gay
#17 | ||
Hatch, Very True, and Army, Thanks for that link brother! So would you do the Street/strip Trans or the competition? I am leaning towards the Street/Strip cause the money saved will get me a good converter... And that seems to be all I would need to have a good time with the car
Military Crew USMC
1992 Mustang LX
13.0 @ 105
I feel like you should be running faster than that..Maybe it's just me?
![]() EDIT: I just realized you got an auto with no stall....Nevermind.
1990 mustang gt
My fox used to do that, especially at the track. I replaced the terminal on the wire from the battery to the starter solenoid. Fixed everything
Burning Rubber in the 5.0 http://www.youtube.com/watch?v=mKGSmRkKQcM95 95 mark8 lsc 95 tbird v8 90 mustang gt 07 silverado v8 08 yamaha r6 to be continued........ foxbodyperformance.com is the way to go |
#20 | ||
Yeah, I think this new cable I have coming will fix it,
And yeah That stock stall is killing me... Once I get a 3-3500 I bet I drop 4-5 tenths.... and then with the new trans behind that... oh yeah, can't wait
Military Crew USMC
Threads Similar to: Went to the Track Today
| Went to the track today | mystang0673 | 99-04 | 41 | December 21st, 2010 03:35 PM |
| went to the track today! wtf? | Broke4.6 | Drag | 26 | August 21st, 2010 06:29 PM |
| went to the track today | riceburnin03 | 99-04 | 2 | March 2nd, 2008 04:26 PM |
| Went To The Track Today | JONJON | 5.0 Mustangs | 36 | December 4th, 2007 07:10 PM |
| went to the track today | Drgnracin72 | The Clubhouse | 8 | February 19th, 2007 02:10 PM |
