CODE 42 TROUBLESHOOTING(fuel mixture too rich)
i am getting a rich fuel mixture and i need help trying to fix it. i would just like to add that it started this after i washed the engine, and has doing it for over two weeks. any suggestions i changed the cap and rotor which seemed to help but only temporarily.
48.47@ 12.58
is this a 93 GT or Cobra ?
(might want to let ppl know what a code 42 is :wink )
sorry it is a 88 mustang gt, aod, speed density
48.47@ 12.58
see i thought it was a 93..
i hate speed den cars.. does it have any aftermarket parts? like fuel injectors/pump
no stock
vacuum test came up ok, and fuel pressure came up ok to, but didnt do the residual fuel test with the key off though
48.47@ 12.58
take a look at your plugs..
some water might have seeped in
i pulled every plug out and they all looked good , every plug looked the same as far as wear is concerned as well
48.47@ 12.58
well if your plugs were good you aren't running rich man.
i honestly think you have water somewhere that you shouldn't.
it is definetely running rich because it will stall and the engine will shake a bit, just trying to figure out where the water could be and after two weeks of nice weather and driving it everyday u think the water would be gone?
48.47@ 12.58
one would think so damn..
sounds dumb but pop the hood and take a blow drier to it for a while??
a blow dryer u gotta be kiddin me. i have been driving it every day the engine fan shoud act like a blow dryer
48.47@ 12.58
i told you it sounded stupid
a blow drier would work WAY better than you fan. you could also try blowing some compressed air around to see if and water shows up...
at this point im willing to try anything, it has gotten better over the last 2 weeks but just cant shake it. might just play the waiting game. i can only narrow the possibiliteis fuel air and spark, its not air, and its getting fuel and if it was getting too much fuel, the plugs would show, which just leaves spark, but what other components to the ignition system would get water in them? this is a intermittent problem which is why it doesnt show up on the plugs
sounds like one of 3 possibles....map sensor got water in it and now is acting up, problem with intake air temp sensor (front of intake on runner port-d/s), or water temp senor. Either of the 2 could be reading cold which will cause a rich condition.
"The gods too are fond of a joke." "If I had only known, I would have been a locksmith. " |
Its probably a sensor. Egr valve sensor, O2 sensors Map sensor. I would check all ur sensors out and see.
48.47@ 12.58
finally... fox guys to help...
i was wondering when you guys would show up.
RLY SRS
Sounds like your MAP Sensor got water in it...That is what my money would be on...
O2 sensors?
- '90 Mustang LX-Sold "Debbie" - '89 Mustang GT- Deceased "Lucy" - '91 Mustang GT-70,000 mi "The Unicorn" |
RLY SRS
Do you know anyone that might have a MAP Sensor that you know is good that you can put on your car to see if that fixes?
if it does just go out and get yourself a new MAP Sensor... |
Threads Similar to: CODE 42 TROUBLESHOOTING(fuel mixture too rich)
| What should my Air fuel mixture be? | demononwheels | 5.0 Mustangs | 6 | August 13th, 2007 12:38 AM |
| Having a problem...need opinion/troubleshooting assisstance | BJL | 5.0 Mustangs | 5 | July 26th, 2007 04:51 PM |
| Troubleshooting Code | KingsLaw | V6 Mustangs | 0 | April 7th, 2007 07:34 PM |
| Fuel Problems Burning Rich / Burning Lean | Steves LX | 5.0 Mustangs | 5 | March 21st, 2007 09:46 PM |
| runs for 15 mins and dies fuel pump circuit open code | jonboy | 94-95 | 0 | March 2nd, 2007 09:14 AM |
