GT40 heads questions
I am looking into buying a set of GT40 heads for my 1993 GT but I really don't know too much about heads. My motor is stock as of now, but I'm wondering what else i would need to change in order for these to work. I've heard springs but I don't want to get into this without knowing what I'm doing first, so any help would be appreciated. Thanks a lot.
1989 Mustang GT
Only thing that would help benefit w/ them heads would be a gt40 or good aftermarket intake. If youre keeping your stock cam them stronger springs arent needed. If you swap the cam to a decent aftermarket one i would recommend springs.
Oh sorry, I forgot to mention that I had the BBK SSI intake. I'm going to get a cam eventually down the line, but I dont know which kind I want yet. Its for my every day car, I just want some extra power to keep up with my dads M3
#4 | |
Depending on what year M3, you will probably need alot more than GT40 heads and that BBK intake to get anywhere near keeping up with him.
I would most likely go with a new set of aluminum assuming that doesn't mean I have to change anything else.
1991 Ford Mustang GT
M3 are light. My dad had a 2000 M5 rated at 398Hp i think. it was really quick
Its an E46 convertible. Its not as fast as youd think off the line but its still faster than my car. Ive got a few other things as well but im just talking about from red lights.
89 GT
If you're going to spend the money, there's far better heads than aluminum GT-40's. Trick Flow, Canfield, AFR and Edelbrock vic jr's will all make more power than them and you can find them used for cheaper than a new set of the GT-40's
#9 | |
Alright thanks a lot. Which would you recommend and how much is a good price for a set of used?
Threads Similar to: GT40 heads questions
| gt40 heads | stang87 | 5.0 Mustangs | 3 | July 6th, 2009 09:18 PM |
| heads help gt40 | rusty2407 | 5.0 Mustangs | 17 | September 22nd, 2008 12:15 PM |
| GT40 Heads | 95stangvert | 94-95 | 13 | February 4th, 2008 12:26 PM |
| GT40 heads? | workinprogress | 99-04 | 3 | January 13th, 2008 03:02 PM |
