Mustang Fanatic
1989 Mustang LX
Porting and polishing my gt40p's
like the title says.
i also ordered the trick flow valve springs to go with the trick flow stage 1 cam. other things i got to go with the upgrade, professional products 70mm throttle body and a cobra 70mm MAF. |
#2 | ||
88Notch 10.59 @132 / 03 Mach 1 13.1 @104
Military Crew USMC
Mustang Fanatic
1989 Mustang LX
Think it's a little optimistic to hope for 270whp?
89 Mustang LX: 347 AFR Comp Cam TFS Track Heat 359rwhp 395rwtq
1988 Mustang GT
Almost worth a "Cool Story Bro!" pic, but not quite.
#5 | ||
Military Crew USMC
Don't waste the time or money with the port work. Just have a good 3 angle valve job and put the new springs on. Have the machine shop check them over real good for anything else that might need to be replaced.
#7 | |
Mustang Fanatic
1989 Mustang LX
You don't think it'd be worth the effort to port/polish? He's gonna polish my cobra intake bottom piece too
#8 | |
Mustang Fanatic
1989 Mustang LX
No. A 3 angle valve job and maybe a little bowl work but that is about it.
Haha the heads are almost done. The port/polish looks pretty sick. Im sure theyll flow better. Ill be at the shop tomarrow, I wanna knock out the exhaust leak on that header.
Probably hurt flow too. I didn't say "no, just some bowl work" because I wanted to see myself post. People screw these heads up all the time trying to port them. Good luck.
91 Mustang GT
1991 sliver GT
If you can do it for free go for it. I had my new heads polished by the machine shop but he owed me one so it was a freebe.
#13 | |
Mustang Fanatic
1989 Mustang LX
well worst come to worst, i guess ill invest in some aluminum ones if these turned out bad. thanx for your input bro
1995 SVT Cobra
My factory Cobra GT40 heads were ported by a guy who used to do the GT40 porting research for Tasca Ford in Rhode Island. Basically he knows what he's doing with these heads. With my Cobra lower intake ported by TMoss, my numbers with an E303 cam are at 275/305. When I had the Edelbrock RPM II intake on this combination, it was at 280rwhp. I switched back over to the ported Cobra intake because the average torque was better with it than the RPM II.
![]() 1995 SVT Cobra #182/4005, 275/305, 217k miles 1996 SVT Mystic Cobra #1666/2000, 267/263, 178k miles 1995 Mustang, 3.8L, 233k miles 1993 Mustang LX, 2.3L, T5 convert, 95 GT suspension swap, 03 Cobra steering rack, 250k miles sold: 1987 GT MM Military Crew Member MM+Cleavage member #21
#15 | |
Threads Similar to: Porting and polishing my gt40p's
| Question concerning porting & polishing | Draeyth | 99-04 | 8 | December 15th, 2009 11:37 PM |
| porting and polishing an intake? | mystang0673 | 99-04 | 1 | February 9th, 2009 05:56 PM |
| Porting and polishing..... great pricing | 99v6stang | 96-98 | 3 | February 16th, 2008 01:23 AM |
| Porting and Polishing | RandoGT | 96-98 | 37 | August 19th, 2007 09:44 PM |
| 2 questions NITROUS and PORTING and POLISHING | 90TANG.GT | 5.0 Mustangs | 11 | July 26th, 2007 02:05 PM |
