#21 | |
1969 Mustang Mach 1
6.824@101.61
./___ _ ____ ___ \. ( ]]] _ _ O _ _ [[[ ) \_ o _ _____ _ o _/ |___| ......... |___| http://www.youtube.com/watch?v=HyYU3...e_gdata_player |
#22 |
89 GT
Exactly.. Linkbar lifters are a better design to begin with plus you can run any roller cam you would in a roller engine. Not only is the cam core stronger so it will resist flex more, but the lifters don't rely on a thin piece of metal and dogbones to keep them in place, so you can turn more rpm without valvetrain instability.
#23 | ||
2ndPlaceSetofSteakKnives
03' Cobra | 3.4 Whipple | SRA Swap | 99' SS | Forged 347 | YSI 16psi | 12 Bolt | 96' Cobra | On3 FF Kit | T45 Source Tranny | 3.55's | 91' GT | GT40 Intake | CAI | Headers | www.fquick.com/99Ls1fever |
#24 | |
Factory hydraulic roller lifters are too tall for early blocks and with a standard base circle cam the lifters will be pushed too far out of the lifter bores in a non roller block which will affect oiling to the lifter. The lifter bores in the roller blocks are taller to work with the taller lifters. A standard base circle cam and link bar lifters is the best option.
#25 |
I was also gonna do this. Good luck man
#26 |
Thanks, We will be starting this build probably next week. I am not sure if we will be ordering the turbo kit first and the cam conversion or just ordering the heads, cam and intake and going from there.
I know that I have been talking to numerous people including the owner of 0n 3 performace and they are a lot of people running stock bottom end with this kit on 6-8 psi. And having no issues. I could for see us running the heads, cam, intake, carb, and turbo kit this season and when the drag season ends tearing the motor down forging it and probably stroking it. Let me know how your build goes. Here is a link to a thread where numerous motor builds are using this turbo kit including stock bottom end cars.
#27 | |
![]() not built for your taste but built for mine |
#28 |
any pointers on swapping out a 5.0 to a 5.8w..
Threads Similar to: Starting a 351W Build
| 351W build | texasmustang12 | 5.0 Mustangs | 18 | June 8th, 2010 09:23 PM |
| 351w build | drgt97 | 5.0 Mustangs | 3 | March 5th, 2010 05:27 AM |
| need help 351w build... | 88stangGT | 5.0 Mustangs | 9 | May 24th, 2009 08:51 PM |
| 351w build | njstang | 94-95 | 4 | May 18th, 2009 10:23 PM |
| 351W Slowly turning, not starting | Unf6Stang | 5.0 Mustangs | 8 | March 29th, 2009 10:54 PM |
