#1 | ||
88Notch 10.59 @132 / 03 Mach 1 13.1 @104
This car is really starting to ....
Ok, I got the 1 gauge power cable to the starter on and buttoned all that up. Out a fully charged red top in the car, hooked everything up and started the car, Had a ruff time turning over but not to bad.. Let the car warm up and took it around the block. Gauges are still telling me the temp is all the way to the right as well as the oil pressure... Pull back into the garage and shut it off, then try and start again... NOPE. same issue..
I have pulled the dash to try and find a bad wire, looked at the computer ground there, I eve started the car with the light switch out, defroster, gauge cluster, and still same issue. I dont think its heat soaking the starter cause that wont explain the gauges... New computer, New starter and cable, New red top... Ground strap to the block is there and good, ground bug next to the water pump on the driver side good... IDK what it could be. I am loosing my mind. This is when a carbed car would be so much easier Tim
Military Crew USMC
1992 Lx
11.39@119.24
computer ground? block ground?
#3 | ||
Computer ground good and tight, Block is grounded as well and is good... I am fixing to set this fucking car on Fire and then replace all the wiring... Naa I need to get a fluke to start testing shit i guess
Military Crew USMC
1984 mustang gt
havent ran it yet. its all stock. lol
might try to scrape those grounds with a wire brush . sometimes they get all nasty and a good scrapin fixes it. well at least thats what happened on my old camaro.
Threads Similar to: This car is really starting to ....
| Starting, dying, not starting.....WTH?? | shadowgames81 | 5.0 Mustangs | 6 | October 7th, 2010 09:40 AM |
| ....not starting!!!! | thedriver33 | 2.3 Mustangs | 2 | September 29th, 2010 06:42 PM |
| not starting | Gt98 | 96-98 | 13 | April 15th, 2009 05:30 PM |
| car not starting | ByPopularDemand | V6 Mustangs | 3 | April 7th, 2007 12:43 PM |
| Car not starting | ByPopularDemand | V6 Mustangs | 6 | January 18th, 2007 10:45 AM |
