LinkBack (1) | Thread Tools |
#1
1989 Mustang GT
What kind of power would i get out of this set up?
I recently got a bunch of stuff in some trades and i was wondering what kind of HP and ETs i could get with all of it.
89 Mustang gt: GT40 heads headman long tube headers off road H-pipe 65mm throttle body 80mm MAF with 24# injectors rear seat delete underdrive pullies drag springs with the air bag in one of them im not expectin any major power gains out of it just would like to know what it would make. i know i could use a new intake and cam. i plan on getting a holley systemax or similar intake and a nice cam soon. So what kinda HP numbers and ETs would come out of all of these parts? Anyone have any suggestion on something i can get to complement these parts for better numbers? |
1989 Mustang GT
also forgot subframe connectors and a redneck ram air setup (replaced stock air filter with one from a ram air setup and left stock tubing and everything).
What trans? and slicks would help!
1989 Mustang GT
sorry its an AOD trans. and this is a street car so slicks wont cut it but i do plan on getting some nitto drag radials in the near future.
idk on hp but I would say mid to lower 14's maybe high 13's...
Honestly I think the heads would be restricted by intake. I would not upgrade one without the other. Add at least a GT40 intake. With a AOD car your 1st upgrade should be gears! you put some 4.10s in a stock 5.0 HO and you will think its the best money you ever spent.
#7 | |
1989 Mustang GT
i would love to have 4.10s but i dont know if they would affect droveability too much. |
Some people I have talked to local said they improved gas mileage with a AOD and 4.10s. I am planning on doing this with mine this spring. Ever notice in your AOD at 85 your only tacking like 2500 rpms lol. the 4.10s let you wind out your gears a little more esp the OD.
uhhh No. Your smoking crack look the 410s are a good gear set for the aod... It does not improve gas milage I went from 18 to about 16 around town.... Lost about 2 mpg thats driving normal, if your not gonna do alot of freeway driving get the 410s man you will love them if you drive the freeway alot get 355s....
What 80mm maf are you running?
[URL="http://providence.craigslist.org/cto/2148862880.html"]1994 Cobra For Sale[/URL] [SIGPIC][/SIGPIC] [QUOTE=Timm10221]Its only a 10 inch Tach that sits right in the center of the dash with LED lights and a Spinner bezel that has dimonds and gold plating.. And when you hit 4500 plus is sounds off (AAHHH SHITT) :cool:[/QUOTE] |
prolly the cobra one
then its not going to work with his car and the 24# injectors
Atomized
you got a decent start with the suspension. Stuff I'd do a t5 swap next or a stall as those trannys kill me
spray and pray |
1989 Mustang GT
im gonna be stayin with the AOD. i would love a t5 but i wouldnt be able to do the swap. there will eventually be a built AOD though. and thanks for the help ive decided to get 4.10 since i rarely ever go on the freeway.
list of parts to order now: 4.10s Nitto drag radials a good intake and a better CAI |
LinkBack to this Thread: http://www.moddedmustangs.com/forums/5-0-mustangs/204531-what-kind-power-would-i-get-out-set-up.html
| 5.0 Mustangs on Forums at Modded Mustangs | BoardReader | This thread | Refback | February 18th, 2011 12:57 PM | |
Threads Similar to: What kind of power would i get out of this set up?
| What kind of power could I get if... | MD5150 | 99-04 | 22 | August 24th, 2010 02:10 PM |
| What kind of power will my combo make? | brad0502 | 5.0 Mustangs | 22 | July 26th, 2010 06:32 PM |
| What kind of power will the 8.8 hold? | jtyson8602 | 5.0 Mustangs | 6 | July 16th, 2009 07:30 PM |
| what kind of power | brianstang | 96-98 | 22 | May 7th, 2008 03:00 PM |
| What Kind Of Power? | boatn70 | 5.0 Mustangs | 30 | December 30th, 2007 12:42 PM |
