smog
Old February 17th, 2011, 08:42 PM   #1
93 Mustang Gt
velasco98 is on a distinguished road
smog
i smogged my car for the third time and i failed once more.
The first time I failed in every category, and the second time I failed in the nox. my nox was like 1200. I failed nox once more but now it was like 800.
I changed almost everything except for the front cats.
Any help would be appreciated, any connections as well. PM
We are in CA Test only
Old February 18th, 2011, 04:54 PM   #2
Sales@JDP is on a distinguished road
NOX code is to much O2. Check for leaks in the welds around the converters. Or the motor is to lean.
Regards,
Don
JDP Motorsports
888-308-6007
Old February 19th, 2011, 09:29 AM   #3
1995 GT
4Ever
Red95_5Oh is on a distinguished road
Send a message via AIM to Red95_5Oh
Have you checked for codes? How old are your 02 sensors? Do you have headers? I live in CA too and hate freakin smoggin! Where do you live? If you are around the bay area I know someone who will guarentee your car to pass... Also check to make sure your EGR works and your PCV is working. also doesn't hurt to sit down and hug your car and tell her you love her lots and dont want to get rid of her!
Old February 19th, 2011, 10:58 AM   #4
93 Mustang Gt
Yea I have headers. My o2 sensors are new. And so is my egr. I live in the bay area. Here's my number hit me up.408 310 9495
Old February 19th, 2011, 04:15 PM   #5
EscortSportage's Avatar
1989 Mustang GT 5.0
i passed Emissions with a smog pump
with factory h pipe NO TIMING! literally 0 timing and heat those cats up good before u go
(MSD ignition might have helped me)
Cage
Maximum Motorsports
Sparco
QH/BE
Nitto
"a huge bad azz motor is nice untill you have to turn or stop"
Old February 19th, 2011, 04:30 PM   #6
ryanw's Avatar
1991 Ford Mustang GT
in my area of california you will fail just for not having your timming at 10 btdc
Trick Flow R intake,
jba headers, 2 1/2" x pipe
flowmaster super 10 mufflers,
255 fuel pump,
3:27 gears
Threads Similar to: smog
I have to smog soon Red95_5Oh 94-95 0 October 21st, 2010 05:36 PM
Hot smog starin 96-98 0 September 23rd, 2009 01:03 PM
Smog inpection Rome704 Southeast 1 May 30th, 2009 12:48 PM
smog kevin86freeman 99-04 8 August 18th, 2008 10:30 PM
EGR and smog Iwannagofast 5.0 Mustangs 6 March 4th, 2008 08:05 AM
