1992 Mustang GT
Please Help! High RPM stumble and....
Ok so here is the issue. When the car is not warmed up and I step on the gas it stumbles almost as if I'm rev'd out. After the car warms up it only does it at higher RPM's (3500-5000) and I was wondering if this issue is causing me to blow seals and gaskets. I blew the rear intake seal, then the front one, and last night I blew the header gasket (2nd time it's happened). And I have to replace both exhaust donuts.
My MODS are in my sig. Any help would be appreciated!
3.73's, GT40P Heads, GT40 upper and lower, underdrive pulleys, TFS 1 cam, double roller timing set, SCT 4 Bank "Eric with a mustache and Mustang Eric?" |
1992 Mustang GT
anyone
1992 Lx
11.39@119.24
yes the front of the intake and back of the intake can make the car run bad if you have the stock pcv system in the car
91 Mustang GT
1991 sliver GT
replace the pvc valve cant be more that $5.00 start with that
1992 Lx
11.39@119.24
what Im saying is it can only be a vacuum leak if he still has the pcv system in the car, if he replaces the pcv and still has a leak there its still gona suck in air through the front and back of the intake into the pcv/upper
1992 Mustang GT
gonna check for vacuum leaks today. I heard a trick of spraying carb cleaner to check.
Threads Similar to: Please Help! High RPM stumble and....
| Occasional stumble | WhiteMamba | 5.0 Mustangs | 57 | September 1st, 2010 08:03 PM |
| occasional stumble/popping | DigitalDC89 | 5.0 Mustangs | 7 | August 30th, 2010 10:57 PM |
| Stumble on take off | 3sportbob | 99-04 | 6 | April 28th, 2010 07:53 PM |
| Stumble / Hesitation - please look | myoshik | 99-04 | 26 | October 22nd, 2007 02:35 PM |
| Acceleration Stumble | Juggalo_X | V6 Mustangs | 3 | June 13th, 2007 03:30 PM |
