1989 Mustang GT
~14@99 (b4 turbo)
fuel pressure test
How can i test the fuel pressure. i been havin random misfires and not sure if its a fuel problem. i borrowed a tester guage, but dont have the slightest clue how to use it.
306 w/ 8.9:1 ON3 70mm turbo kit - 9#'s boost arp chromoly studs 47# FRPP - 255 walbro 3.73 - tremec 3550 - zoom hp kevlar clutch msd 6a + blaster coil lowered. sfc. HID delete egr-smog-cats-a/c-foglights battery reloc QuarterHorse, BE, EA |
1991 Ford Mustang GT
connect the fuel pressure gauge to your fuel rail ( port ). It looks like the same port you have on your tires, its near the front of the intake. start the car check the gauge and see what your fuel pressures at, then pull the vac line to your fuel pressure reg and again check to see what your fuel pressures at
1989 Mustang GT
Yea youll have 2 metal tubes (is stock & EFI) 1 has a what looks like tire or r12 freon port, just screw on and crank her up
Threads Similar to: fuel pressure test
| Zero fuel pressure | Vabeachmustang | 2005 - 2010 | 43 | January 7th, 2010 02:26 AM |
| Fuel Pressure Regulator Leaking Fuel | Buttaz | V6 Mustangs | 4 | August 17th, 2007 11:41 AM |
| Fuel Injectors/fuel pressure | 00silvergt | 99-04 | 4 | August 2nd, 2007 09:54 AM |
| No fuel pressure, Fuel gauge went above full and stayed. | woodz72 | 96-98 | 6 | July 10th, 2007 06:58 PM |
| fuel pump fuel pressure stuff | JBIGBOOTSY | 5.0 Mustangs | 2 | April 26th, 2007 03:31 PM |
