Quick Mass Air Flow Question...
Old February 19th, 2011, 01:20 AM   #1
1989 Mustang GT
Black89gt is on a distinguished road
I have seen 5+ cars on youtube over the last couple months, and Just seen a pic of one on AM.com and its a 5.0HO the stock fox setup for a GT and I have seen most w.o stock air intake hose, and w. BBK cold air. Well I have seen these cats running on Vid w.o a Mass air flow sensor... I would love to get rid of mine but i dont see how the car would even run..
Old February 19th, 2011, 11:28 AM   #2
'88 Mustang GT
DigitalDC89 is on a distinguished road
Send a message via AIM to DigitalDC89
'88 (minus CA cars) and older Mustangs had Speed Density instead of Mass Airflow. unless you convert your car back to SD, youre not gunna get rid of it. i wouldnt want to anyway. MAF as alot better then SD is, since its literally measuring the air entering the engine, versus SD calculating it.
BUT, if you are completely dead set on getting rid of it, i will GLADLY trade you my '88 computer for your computer and MAF sensor.
all you would need to do would be to connect the Baro Sensor (on firewall behind intake manifold) to a vacuum source.
somebody please correct me if im wrong though.
'02 Mustang GTm Convertible - N/A Cammed Daily
'88 Mustang GTm - 1/4 Mile Build - 750rwhp Project
'97 Saturn SL2m - Ex-Nitrous Build - Back-Up Daily
Old February 19th, 2011, 04:04 PM   #3
EscortSportage's Avatar
1989 Mustang GT 5.0
dont go SD
Cage
Maximum Motorsports
Sparco
QH/BE
Nitto
"a huge bad azz motor is nice untill you have to turn or stop"
Old February 19th, 2011, 04:33 PM   #4
ryanw's Avatar
1991 Ford Mustang GT
Originally Posted by EscortSportage View Post
dont go SD
+1
Trick Flow R intake,
jba headers, 2 1/2" x pipe
flowmaster super 10 mufflers,
255 fuel pump,
3:27 gears
Old February 19th, 2011, 05:09 PM   #5
302Army187's Avatar
'89 LX 'Vert
10's or bust... Literally.
302Army187 has a spectacular aura about302Army187 has a spectacular aura about
lmao
why in the balls would you want to get rid of the MAF.
so the car will run like shit with minimal mods?
if you just hate the looks of it, get a intake tube from anderson that goes into the fender and puts the maf in there with it.
H/C/I 302 + nitrous for now... supercharger/turbo soon?
www.youtube.com/Xarmy187
Please support my YouTube channel! My videos don't disappoint!
Old February 20th, 2011, 08:08 PM   #6
1989 Mustang GT 5.0
dude MAF and the ford EEC4 ECU are a great combination even today our old ECU is very good i hear, u want all the electronics working correctly with a good tune, the engine will make the most HP/TRQ and be the must efficient
Cage
Maximum Motorsports
Sparco
QH/BE
Nitto
Old February 20th, 2011, 09:25 PM   #7
1989 Mustang GT
I was just wondering how it was possible to run a car w/o a mass air flow. The cars had nothing but TB to a maybe 2" long tube w/ a filter on it. I would rather keep Mass air over SD anyday. Just thought maybe there was a trick i didnt know of.
Old February 22nd, 2011, 06:33 AM   #8
302Army187's Avatar
'89 LX 'Vert
because 1988 and older mustangs did not have MAF meters............ they get there info off of vacuum changes.....
Old February 22nd, 2011, 08:58 AM   #9
Authorized Vendor
Matt Cramer's Avatar
Matt Cramer is on a distinguished road
There are also tuneable aftermarket ECUs that use a MAP sensor instead of MAF. This can come in handy for turbo or other wild builds as you don't have to find a MAP sensor that matches your air flow level. We've found that there's a small but measurable horsepower gain from removing the MAF - it's not very much of a restriction like on some cars, but you may find 2 hp or so from removing it.
Threads Similar to: Quick Mass Air Flow Question...
Mass Air Flow Question 281SLEEPER2v 99-04 1 December 12th, 2009 09:24 PM
mass air flow Question jrock 99-04 3 November 19th, 2008 09:14 PM
mass air flow question arice 94-95 5 May 7th, 2007 01:24 PM
mass air flow FastBack71 5.0 Mustangs 1 February 1st, 2007 07:33 PM
