Whats this Black Box?
Old February 20th, 2011, 02:41 PM   #1
Timm10221's Avatar
88Notch 10.59 @132 / 03 Mach 1 13.1 @104
Timm10221 is on a distinguished road
Ok, So I did all the grounds and all is good to go... 4 gauge cable from Block to Chassis and 4 gauge cable from Block to Battery Neg. Now to turn it on,
I put the key to the run position and I get my tach going crazy and it is bouncing between 4-5 rpm mark. And I have a high pitched buzzing sound, kinda sounds like a broken horn.. and the Fuel pump wont prime.
I located the sound, it is coming from this Black Box that is mounted right behind the Coolant over flow tank. It has a wiring harness connected to it and inside the box looks like a computer chip or what not. What is this box and could this box taking a shit cause my issue...
I decided to turn it over for shits and giggles and it turns over fucking amazing.. fast as shit, hasn't turned over this well ever...
I just need to know what this black box is and maybe replace it.
Military Crew USMC
Originally Posted by JBIGBOOTSY
I usually kill the hookers(so I don't have to pay them) then I take their hands for my collection.
Originally Posted by homebrewed
Perversion mixed w/ mild tech... God I love ModdedMustangs!!
Originally Posted by flyin ryan View Post
Three Filipino hookers and enough for a co pay at the local clinic
Old February 20th, 2011, 04:36 PM   #2
FastStang91Lx's Avatar
1991 Mustang LX 5.0
I can't think of anything like that on my fox, but maybe if you get a pic on here for the SN crowd it will be better help
Old February 20th, 2011, 08:25 PM   #3
1992 Lx
11.39@119.24
pics phaggot
Old February 20th, 2011, 09:12 PM   #4
Ohsplat's Avatar
1983GT
No motor or trans
Ohsplat is on a distinguished road
Send a message via Yahoo to Ohsplat
Sounds like a external ignition, or a car alarm.
Old February 20th, 2011, 09:12 PM   #5
fogged306's Avatar
89 GT
Sounds like the ignition control module. I forget where they are on a SN, but they're under the hood. pics would definitely help.
Old February 20th, 2011, 10:37 PM   #6
Timm10221's Avatar
Military Crew USMC
Old February 20th, 2011, 10:45 PM   #7
Daves94vert is on a distinguished road
it's your ccrm where various relays are kept including yoour fuel pump relay.
Old February 20th, 2011, 10:46 PM   #8
ryanw's Avatar
1991 Ford Mustang GT
looks a little like a Air bag sencor, not sure though. Was that on the radiator saport ?
Trick Flow R intake,
jba headers, 2 1/2" x pipe
flowmaster super 10 mufflers,
255 fuel pump,
3:27 gears
Old February 20th, 2011, 10:47 PM   #9
The Big Spoon
jessemachone's Avatar
88 5.0 5 Speed Notch <><
never fast enough
jessemachone is a glorious beacon of lightjessemachone is a glorious beacon of lightjessemachone is a glorious beacon of lightjessemachone is a glorious beacon of lightjessemachone is a glorious beacon of light
+ 1
Black Stang Crew
Originally Posted by 302Army187 View Post
old 5.0's are like a box of chocolates.......... never know what your gonna get
Old February 20th, 2011, 10:49 PM   #10
Timm10221's Avatar
That would make sense why my fuel pump wasn't priming if that is shot..
Military Crew USMC
Old February 20th, 2011, 10:51 PM   #11
The Big Spoon
never fast enough
yup. they go bad. I have seen people bypass the one in the ccrm and add it elswhere in the system. remember that you need to keep it sealed if you heep it out there because you don't want it getting wet.
Black Stang Crew
Old February 20th, 2011, 11:04 PM   #12
Timm10221's Avatar
So which one is it...
Advance Auto Parts: Relay Control Module by BWD - Part RCM12M
Advance Auto Parts: Relay Control Module by BWD - Part RCM13M
Advance Auto Parts: Relay by Factory Air - Part 37514
Advance Auto Parts: Body Control Computer by Cardone - Part 73-70020
Military Crew USMC
Old February 20th, 2011, 11:29 PM   #13
The Big Spoon
never fast enough
yours should be marked. autos are different than manual i think.
Black Stang Crew
Old February 20th, 2011, 11:32 PM   #14
Timm10221's Avatar
Well its a F48F-12B577-AA type R, But autozone or advanced doesnt call it a CCRM, But thats what it is for sure... The only things I can find that look like it are what I put in the links.... Maybe I will just take it into the store tomorrow and see if they can order me one..
Military Crew USMC
Old February 20th, 2011, 11:36 PM   #15
The Big Spoon
never fast enough
sounds like a decent plan to me!
Black Stang Crew
Old February 20th, 2011, 11:45 PM   #16
Timm10221's Avatar
I swear, If I get this new CCRM and it doesn't fix this issue Im going to cut every wire out of the car and re-wire it all and go Carbed.. lol I dont think my new grounds would have done this failure, I have grounded the battery to the block and then the block is grounded to the frame and I also have a wire going from the neg terminal to the chassis.. I wanted to make sure it was grounded out good lol.
Military Crew USMC
Old February 20th, 2011, 11:53 PM   #17
The Big Spoon
never fast enough
shit's old man - old shit breaks. Don't carb your car because of stupid electrical crap!!!
Black Stang Crew
Old February 20th, 2011, 11:56 PM   #18
Timm10221's Avatar
lol, Im just getting tired of spending money on replacing this electrical crap lol.
Military Crew USMC
Old February 21st, 2011, 12:13 AM   #19
1992 Lx
11.39@119.24
my car blows fuel pump relays. Dunno why. Got the power wire that goes to the relay jumped to the fuel pump. Only thing the dam relay does is makes the fuel pump prime. So when my keys to on my fuel pumps always on lozlzllzlzl
Old February 21st, 2011, 12:22 AM   #20
Billy Weston
C MY 4D's Avatar
2003 Cobra
11.14@124.36
iTrader: 8 reviews
Sounds like a voltage/ground issue to me..... CCRMs make noise when under powered.
TT Build in progress.......
Threads Similar to: Whats this Black Box?
Guess who just signed the papers to a brand new 2011 5.0 Black on Black Sexiness G.T. Rags The Clubhouse 94 August 17th, 2010 08:07 PM
clutches.whats good whats junk? i8achevy4u 5.0 Mustangs 9 October 21st, 2009 10:38 PM
looking for pics of black cars with flat/satin black stripes bullitt5576 Pictures 0 March 30th, 2009 11:48 PM
whats the point of freaking a black and mild White Thunder The Clubhouse 0 July 8th, 2008 12:04 AM
