Tuning Issues 5.0 w/trick flow heads
Old April 23rd, 2007, 12:04 PM   #1
1slowhatch is on a distinguished road
I have a stock bottom end 5.0 w/trick flow track heats, bbk ssi, 1.7 roller rockers, tfs stage 1 cam, shorties, offroad h, flows, cold air, stock throttle body, adj regulator, bbk rails, stock mass air and injectors.
I have several questions, first off, i finally got it running and it isn't quite running right. Lots of idling issues, and doesn't quite make the power it should. What timing should i have? Spout in or out? Fuel pressure?
Old April 23rd, 2007, 12:13 PM   #2
angermgt's Avatar
angermgt is on a distinguished road
stock timing is 10 degrees, you have to unplug the connector, not the main connector the little one to set base timing. as far as fuel pressure, should be about 39 but if you lean out you got to turn base up 10lbs to make your injector bigger and thats with vac. disconnected. unless you have handheld tuner it gonna be hard to figure out where you need to be. you have aftermarket rails why not get bigger injectors and you have a cam intake why not get a bigger throttle body. let that thing breathe.
490whp/432wtq, V2 13lbs. boost, 3.33 pulley
Old April 23rd, 2007, 12:56 PM   #3
yeah, i have a larger throttle body, just won't clear throttle linkage to valve covers. also, on dyno results, 19lbs and stock throttle body doesn't really make any less horsepower, from what i've read. i understand that usually head/cam/intake cars run better on locked timing around 35 degrees. any one on here have idle issues with trick flow heads on stock fuel injection?
Threads Similar to: Tuning Issues 5.0 w/trick flow heads
HELP! 5.0 w/trick flow heads..Rockers setup wrong? Pushrods? 1slowhatch 5.0 Mustangs 16 March 3rd, 2009 10:08 PM
Top End Kit AFM or Trick Flow rvdooley 5.0 Mustangs 5 November 12th, 2007 07:22 PM
whats the cfm for trick flow heads White Thunder 5.0 Mustangs 44 October 18th, 2007 10:59 PM
trick flow Iownastang 5.0 Mustangs 7 July 6th, 2007 01:50 AM
trick flow high port heads anyone? ih8chevy 5.0 Mustangs 6 April 11th, 2007 12:11 AM
