Any AOD experts?
So when I first got my mustang I changed all the fluids, including rear and trans. Trans would start slipping bad in OD only after flooring it hard into passing gear. This was ok with me so I just started to drive it mostly in D unless on a long trip then I would put it into OD and would be hit or miss weither it would work.
So now when the trans is cold (start the car and go) it doesnt want to shift from 1 -2. It pauses and then finally after a sec or 2 kicks into 2nd gear. When I stop at the first stop sign at my house it wont downshift unless i do it manually. After the trans warms up all the gears work fine except it will not upshift into OD at all now. It used to kick in and just free rev like it was in N. Now it wont go from 3rd to 4th at all. I quess im trying to figure out if this sounds like my computer or a sensor, or if the valve body needs rebuilt. |
1989 Foxbody LX Notchback
11.67 @121.4
The best guy to ask about this is Dan (screen name silverfox) over at clickclickracing .com.
'89 Fox 306, F cam, 1.7 roller rockers, TF upper and lower, TF heads, Vortech V1 t-trim at 8 lbs, TKO 5 spd, 26" ET streets. |
1990 ford mustang GT
this happened to me. went to the transmission specialist and they rebuilded a new tranny.
Found a pretty good write up here. From what is stated there I think its a sticky valve. Im gonna pull the valve body if this snow ever melts.
http://www.becontrols.com/ourfaqs/ao...1.htm#02185980 Last edited by Ohsplat; February 22nd, 2011 at 06:03 PM. Reason: forgot link |
Threads Similar to: Any AOD experts?
| auto experts | JoshDrex00gt | 99-04 | 47 | January 8th, 2011 10:06 PM |
| C4 Experts Please Help! | e3sean | 5.0 Mustangs | 8 | April 26th, 2009 10:32 PM |
| Any Tv experts out there? | GTblackprodigy | The Clubhouse | 25 | December 5th, 2008 02:54 PM |
| Google Experts Come Hither... | 1FastFox | The Clubhouse | 5 | September 26th, 2008 07:02 PM |
| HELP PLEASE YOU EXPERTS | sniperrider | 5.0 Mustangs | 21 | October 13th, 2007 10:57 PM |
