Check engine light
I have a 92' 5.0 and the check engine light flashes every once in a while. I don't have a code scanner. But someone was telling me that you can jump two wires on the obd1 plug and then turn your key on and it will flash the check engine light for which ever code it has. If anyone can tell me how to do this it would be greatly appreciated.
Please search the forums... im sure you will find your answer no more then 3 pages into the topics.
1991 Ford Mustang GT
KOEO, KOER, CMM and balance test codes 2 digit and 3 digit
DIY KOEO/KOER/Cylinder Balance Self-Test Procedure
Thank you both of you.
Threads Similar to: Check engine light
| check engine light | njwbd | 96-98 | 7 | August 8th, 2010 09:02 PM |
| NO more check engine light | badf150boy123 | 99-04 | 3 | March 4th, 2008 12:21 AM |
| need help with check engine light | 02MiNeRaLgRaYGT | 99-04 | 3 | November 30th, 2007 04:05 PM |
| Check Engine Light On '01 GT | OcOnnor220 | 99-04 | 24 | September 26th, 2007 04:58 PM |
| check engine light | 02ATIstang | 99-04 | 24 | May 22nd, 2007 05:03 PM |
