GT40 valve train question
Old February 21st, 2011, 08:38 PM   #1
1990 5.0 Smokin' AOD LX
14.27@100.77
Siegedg505 is on a distinguished road
I have a seat of GT40 Heads that are in need of rocker arms, springs and valves. My question is can the stock E7 valve train be placed on the GT40 heads?
90 Mustang LX 5.0 T5 swapped,Mac CAI,intake,Timing,E-Fan,headers,H Pipe,Dumps,Gears,Control Arms,and diet
http://www.fictionalversus.com/index.php my second love
Old February 21st, 2011, 08:49 PM   #2
Ohsplat's Avatar
1983GT
No motor or trans
Ohsplat is on a distinguished road
Send a message via Yahoo to Ohsplat
Nope. I believe the valves are larger. Have you checked the valves to see if they are bent or bowed? I have taken many sets off junk yard vehicles and have always had to replace the springs and seals, never had to replace the rockers or valves.
Old February 22nd, 2011, 02:51 AM   #3
1988 5.0 is on a distinguished road
do them gt40 heads fit a 98 4.6gt cause my friend told about them.
Old February 22nd, 2011, 06:14 AM   #4
cleangtvert's Avatar
1991 gt vert
cleangtvert will become famous soon enough
i was kinda wondering if i could use the springs from the e7'si have (46k miles)on the p's i have with stock cam
Old February 22nd, 2011, 06:49 AM   #5
BULLET20XD's Avatar
BULLET20XD is on a distinguished road
No, the GT40s are OHV heads, The 4.6 is a OHC 2v motor.
1990 LX 5.0
2000 Expedition
2002 Honda Accord
One tea cup Chihuahua guard dog!!!!!!!
Old February 22nd, 2011, 07:04 AM   #6
ok thanks just wondering so wuts the best heads i could go with
Old February 22nd, 2011, 08:48 AM   #7
Smirnoff's Avatar
1982 GT t-top
no proof of purchase
Smirnoff is on a distinguished road
you could if you love valve float, don't be a cheap bastard go spend a couple bucks on new springs
Old February 22nd, 2011, 09:51 PM   #8
BULLET20XD's Avatar
If you have a 5.0 then Gt40s or Gt40p heads, if you have a 4.6 i have no clue. OHC is the new standard on engines nowdays. Less friction in the motor and less chance of a failure, even at high rpms. OHC motors will turn higher than a OHV motors anyday.
1990 LX 5.0
2000 Expedition
2002 Honda Accord
Old February 22nd, 2011, 09:59 PM   #9
1991 gt vert
gt 40's or gt40p's are not ohv
Old February 22nd, 2011, 10:04 PM   #10
1991 gt vert
yeah i know i think a spring kits only $120
Old February 23rd, 2011, 06:43 AM   #11
BULLET20XD's Avatar
Do some research, ANY Ford windsor head is a OHV head/engine! Ford has not built a OHV engine since they dropped the Explorer 5.0 in 2001. The OHC engine started in the Crown Vic in early 90s then the Mustang in 96. OHV means Over Head Valve. OHC means Over Head Cam. GT40s do not have a cam on top of them!!
1990 LX 5.0
2000 Expedition
2002 Honda Accord
Old February 23rd, 2011, 06:51 AM   #12
BULLET20XD's Avatar
Here you go
An overhead valve (OHV) engine, also informally called pushrod engine or I-head engine, is a type of piston engine that places the camshaft within the cylinder block (usually beside and slightly above the crankshaft in a straight engine or directly above the crankshaft in the V of a V engine), and uses pushrods or rods to actuate rocker arms above the cylinder head to actuate the valves. Lifters or tappets are located in the engine block between the camshaft and pushrods.[1] The more modern overhead camshaft (OHC) design (still literally overhead valve) avoids the use of pushrods by putting the camshaft in the cylinder head.
yes they are OHV!!!
1990 LX 5.0
2000 Expedition
2002 Honda Accord
Old February 23rd, 2011, 07:46 AM   #13
98 cobra
1badcob is on a distinguished road
Home boy is right! Good job bro but to answer the real question as a fact... No the gt 40's will not go on a 4.6 anything!!! Gt 40's are pretty good heads for a good power increase but it just depends on how much you wanna spend. Edelbrock or AFR is two of the best! Proven
Old February 23rd, 2011, 01:05 PM   #14
mdbstang's Avatar
93 vert
mdbstang is on a distinguished road
To the OP,if the gt-40 heads have strait valves don't get new ones.All i did to mine was clean them good make sure they are flat and lapped the vavle seats,then i put good valve stem seals on them and got a set of springs locks and retainers from thumper.You have to run good springs if you have an aftermarket cam.Even if you use the stock cam i recomend decent springs.I have seen people run them with stock E7 srings and rocker on a stock set up but the valves will not fit.Let me know if i can help any more
Old February 23rd, 2011, 11:20 PM   #15
1991 gt vert
duh sorry it was a long day at work yesterday lol. iwas thinking ohc. i went to bed just after that post. must have been half asleep.
Old February 24th, 2011, 01:49 AM   #16
BerniniCaCO3 is on a distinguished road
hah, yes, the popular use of OHV has always bothered me!
Pretty much every engine ever made has been over head valve in at least the last 40 years, and has been dominant I think since Chrysler invented it.
Overhead cam engines are still overhead valve engines, they're just a subset thereof. The valves are still in the head-- as opposed to being located outside of the end, next to it! As in the side valve engine.
The other option was a side valve engine... the valve was parallel to the head, and the air came into the cylinder head from the side rather than from the top.
However, this meant the air made at least a couple extra elbows, really restricting airflow and adding resistance, which is bad for fuel efficiency as well as raw power.
The reason to make a side valve engine was machining geometry, they were easier to make until methods got better.
If it's not overhead cam, I prefer calling them pushrod engines: more accurate and technically specific than overhead valve!
Threads Similar to: GT40 valve train question
Valve train help Katen Classic Mustangs 15 May 11th, 2008 11:44 AM
Heads/Valve train Question 01ROUSH 99-04 20 April 14th, 2008 07:28 AM
Cam and valve train??? flamed 98 gt 96-98 8 November 2nd, 2007 01:58 PM
valve train chatter question USMC SCOUT SNIPER 5.0 Mustangs 0 January 11th, 2007 09:19 PM
Valve Train Noise? superbeef1000 99-04 3 September 10th, 2006 07:42 PM
