recommended stock HO rebuild kit? ('90)
Old February 21st, 2011, 11:20 PM   #1
BerniniCaCO3 is on a distinguished road
Hi--
Looking for a basic rebuild kit, gaskets, bearings, rings, and a double roller timing chain. And an oil pump-- why not.
Pistons themselves are solid and to spec.
There are dozens of options from all sorts of vendors, so it's hard to choose.
I've been told that "meh, doesn't matter-- just go to napa"
But figured I'd ask on this forum first for your experiences, and if there's a vendor you'd particularly recommend, and vendors you would run from :-)
thanks!
-Bernard
Old February 22nd, 2011, 08:14 AM   #2
302Army187's Avatar
'89 LX 'Vert
10's or bust... Literally.
302Army187 has a spectacular aura about302Army187 has a spectacular aura about
summit sells pretty good kits.
I peiced all my stuff together from summit, and spent about $400 with everything. bearings, rings, gaskets.
H/C/I 302 + nitrous for now... supercharger/turbo soon?
www.youtube.com/Xarmy187
Please support my YouTube channel! My videos don't disappoint!
Old February 22nd, 2011, 01:34 PM   #3
fogged306's Avatar
89 GT
$400? Im assuming you got pistons with that?
If you're just doing a stock rebuild a NAPA kit or a summit kit will be fine. If you want to do a little better than stock replacement parts, look for a kit with clevite 77 bearings. You should be able to find everything for around $200-250 or so for stock replacement stuff. If you plan on more performance down the road then get better bearings and rings. The rings should be chosen based on what type of performance you go with if you think you will go that route.
Old February 22nd, 2011, 09:48 PM   #4
Sounds good.
What do you mean, "what type of performance"?
Well rather... if I do go for performance in a year's time, it would be for low-end torque. But how would that influence ring choice?
Old February 23rd, 2011, 12:40 AM   #5
fogged306's Avatar
89 GT
As far as if you're going to go with forced induction or nitrous or just a N/A setup. It also depends on how much power you're going for. If you're keeping the RPM down and not looking to go crazy, a standard ring package will be fine. If you plan on big power there's better options out there, but they do cost more.
Old February 23rd, 2011, 07:05 AM   #6
302Army187's Avatar
'89 LX 'Vert
no. $400 is with $56 EACH head gaskets, because I need wire-loc head gaskets, good rings, and bearings, and all the other little things.
assembly lube, break in oil, and a few other things like that are also included in that price.
Old February 23rd, 2011, 07:07 AM   #7
302Army187's Avatar
'89 LX 'Vert
here is the list of what I ordered.
ARP-100-9904 THREAD SEALER 1.7 OZ B Shipped on
1/12/2011 $8.75 1 $8.75
CCA-127 LUBE A Shipped on
1/12/2011 $12.95 1 $12.95
CCA-159 CAMSHAFT BREAK-IN LUBE 12 OZ. B Shipped on
1/12/2011 $10.95 1 $10.95
FEL-OS34508R OIL PAN SET B Shipped on
1/12/2011 $26.25 1 $26.25
FEL-TCS45449 TIMING COVER GASKET 79-97 B Shipped on
FEM-4125MA MAIN BEARING SET B Shipped on
1/12/2011 $38.99 1 $38.99
FEM-8-2600CP ROD BEARINGS B Shipped on
1/12/2011 $34.99 1 $34.99
FMS-M-6701-B302 VPN REAR MAIN SEAL B Shipped on
1/12/2011 $11.88 1 $11.88
SLP-E-458K PISTON RING SET B Shipped on
1/12/2011 $68.99 1 $68.99
SLP-SPG1 Plastigage 0.001"-0.003" B Shipped on
1/12/2011 $2.39 1 $2.39
SME-904000 4.000 FIXED RING COMP B Shipped on
1/12/2011 $28.95 1 $28.95
TFS-2855 INT GSKTS 1/16IN SBF PR B Shipped on
1/12/2011 $19.95 1 $19.95
TFS-51400901 LOC-WIRE GASKET EACH FORD B Shipped on
1/12/2011 $56.95 2 $113.90
NOTE - Final price total may vary on foreign orders, items shipped directly from the manufacturer, hazardous materials, or in other special circumstances—call Customer Service at 1-800-517-1035 if you have any questions. Part Total $391.89
Order Charges
Delivery and Handling Charge $12.95
Total Charges $404.84
Old February 23rd, 2011, 07:32 PM   #8
Thanks for the parts list :-)
Yeah, I don't mind paying a little more, especially since I'm not buying pistons...
Were the $113 gaskets worth the $?
This engine won't see so much severe duty, but I would like it to see serious service life & longevity.
Old February 24th, 2011, 04:13 AM   #9
302Army187's Avatar
'89 LX 'Vert
the head gaskets are that expensive because they are "wire-loc" head gaskets.
my cylinder heads are o-ringed. so the gaskets have a extra ring in them to match up with the head.
its ment to help not blow head gaskets when using power adders. But I got these heads for cheap, and didn't want to mill them down to get rid of the o-ring. so I have to buy these expensive head gaskets.
if you bought them for your car they wouldn't even work, because your heads are not machined to recive them.
that being said, I always recommend a high quality fel-pro head gasket over cheap stock replacment ones.
Threads Similar to: recommended stock HO rebuild kit? ('90)
5.0 HO vs 5.0 Explorer= stock rebuild=better?? 6f09 5.0 Mustangs 1 September 24th, 2010 03:21 PM
5.0 HO vs 5.0 Explorer= stock rebuild=better?? 6f09 5.0 Mustangs 1 September 23rd, 2010 07:56 PM
recommended cams? Boostang 96-98 8 February 13th, 2009 12:57 PM
Recommended Sequentials DanTheMan 99-04 6 February 1st, 2008 03:55 AM
rebuild kit for a stock 302 flattusmaximus78 5.0 Mustangs 15 January 24th, 2008 06:47 PM
