torque converter question
Old February 21st, 2011, 11:48 PM   #1
1990 ford mustang GT
bennyjet846 is on a distinguished road
so i'm about to drop my transmission again to put in a 3000 stall converter in a month or 2 from now. quick question. is putting a torque converter with 3000 stall exactly the same as putting a regular stock torque converter on?
Old February 22nd, 2011, 10:22 AM   #2
dblzroracin's Avatar
92 Mustang GT vert
dblzroracin is an unknown quantity at this point
Send a message via AIM to dblzroracin Send a message via Yahoo to dblzroracin
It will install the same.
www.bbandtracing.com
Old February 22nd, 2011, 11:00 AM   #3
mustangtommy's Avatar
'92 Mustang GT
mustangtommy is on a distinguished road
Send a message via Yahoo to mustangtommy
ya it will install as long as you get a lock up converter if you get a non lock up i believe you have to swap out the input shaft for the tranny....someone correct me if im wrong
not built for your taste but built for mine
Old February 23rd, 2011, 12:08 AM   #4
what's the difference between a lockup converter and a non lockup converter?
Old February 24th, 2011, 06:04 PM   #5
'82 Mustang GT
balls'87 is on a distinguished road
non lockup convertors, dont get nearly as good fuel mileage as a lockup convertor. A lock up convertor actually has a clutch plate in it much like a manual clutch, but smaller. the clutch is only engaged when cruising, not using much throttle. When engaged it convertor is more efficient, giving better mpgs, and less heat.
Threads Similar to: torque converter question
Which Torque Converter? red99gt 99-04 5 June 9th, 2010 02:00 PM
new torque converter momogt 99-04 2 May 13th, 2010 09:49 PM
not your normal torque converter question johnr2001 99-04 6 March 21st, 2009 10:55 PM
Trans and Torque converter question. RayzerFish Modular Mustangs 3 July 24th, 2008 11:58 PM
torque converter 06Stanger 2005 - 2010 0 July 29th, 2007 11:16 AM
