Shaking Problems
Old May 10th, 2006, 02:47 PM   #1
garyvang is on a distinguished road
Shaking Problems
My mustang shakes about about 110 - 120 mphs...and when i brake..the whole car shakes.......could it be my brake rotors or my control arm......Any Suggest on what it is because i need to fix it soon for the nitrious...
Old May 10th, 2006, 03:07 PM   #2
stang fanatic's Avatar
stang fanatic is on a distinguished road
look more into your suspension for those issues...warped brake rotors usually just cause violent left to right jerks when the brakes are applied...look for bad tie rods or worn bushings
"The gods too are fond of a joke."
"If I had only known, I would have been a locksmith. "
Old May 10th, 2006, 05:04 PM   #3
1slo5.0's Avatar
1990 Mustang LX
9.36@143 mph
Re: Shaking Problems
Do you get a pulsation in the brake pedal when you apply the brakes? Sounds like you have some warped front brake rotors. The other vibration your are experiencing at high speed is possibly wheels out of balance. Go have all of your tires balanced.
Old May 10th, 2006, 07:04 PM   #4
good thought about the wheels there....look at your driveshaft too. Mine had a real bad vibration that got worse as i went faster and found the u-joints about 90% siezed and actually in the long run had also caused tailshaft housing damage in my trans...
Threads Similar to: Shaking Problems
my car is shaking? villatic V6 Mustangs 44 June 22nd, 2007 09:09 PM
Shaking at the wheel Wilson00V6 V6 Mustangs 3 December 10th, 2006 08:47 AM
Grinding Or Shaking Sound Bill 5.0 Mustangs 20 November 3rd, 2006 11:59 AM
Car shaking below 1500 rpm 90Stang 5.0 Mustangs 5 August 25th, 2006 01:40 PM
intense shaking around 900-1000 RPM niggadrew 5.0 Mustangs 4 August 24th, 2006 04:47 PM
