starting problem
Old February 22nd, 2011, 05:19 PM   #1
89 hatch
itsjustamustnag is an unknown quantity at this point
starting problem
swear this car starts when it wants to
will start for 2-3 days and then nothing half roll over- then will just start after jump
today solenoid was that only thing that made noise
if i jump it it pops right off--stays at 12.6 with jumper on turn jumper off and slowly drains down to 10.8ish (dont know if its because of my underdrive). if i rev it up it will go to 14.6-14.8
new interstate battery, remanufactured alternator
could it be solienod, crappy connector on alternator, starter going out or bad power feed wires---not a clue also when i turn on headlights 1-2v drop, heat another1-2v drop, turn signal on with rest of this sitting at 8v in red
Old February 22nd, 2011, 05:31 PM   #2
fogged306's Avatar
89 GT
The battery drains to 10.8 when the car is running or when it's off?
Old February 22nd, 2011, 05:41 PM   #3
89 hatch
running-- off i think it stays somewhere around there
Old February 22nd, 2011, 06:10 PM   #4
fogged306's Avatar
89 GT
Check all your connections and if everything looks good, have the alternator bench tested. Sounds like its either a poor connection somewhere or a faulty alternator.
Old February 22nd, 2011, 08:37 PM   #5
gripthenboost's Avatar
91 Mustang GT
1991 sliver GT
gripthenboost will become famous soon enough
Do you have to jump the car to start it?
Old February 22nd, 2011, 08:52 PM   #6
89 hatch
yes starter rolls once or less then once today just got click at solienod
have to jump everytime-alternator puts out 14.6 but only at 1.5 or higher
think one of my plugs to alternator has one wing clip broken
Old February 22nd, 2011, 08:54 PM   #7
89 hatch
jumper brings it to 12.6v and it pops off everytime
Old February 22nd, 2011, 09:05 PM   #8
fogged306's Avatar
89 GT
14.6 is a touch high. Standard voltage for a working charging system is between 13.8 and 14.4v and this is at idle. The voltage regulator in the alternator could be bad if you've got a spread of 10.8 to 14.6v. I still say check all connections first, then test the alternator.
Old February 24th, 2011, 07:55 PM   #9
89 hatch
comes to find out that the new battery from interstate was a dud 2 weeks in car and couldnt pass load test--also guy in shop told me to take the ground off the small terminal on solienod and put it between the mount plate and the wheel housing after i make a little bar metal--works great now----after all everythigns new(alternator, solienod,starter, battery and wires) lmao
Threads Similar to: starting problem
Starting problem Chris951 5.0 Mustangs 26 March 29th, 2009 04:19 PM
another fox starting problem 90mustang50 5.0 Mustangs 2 March 28th, 2009 12:49 PM
starting problem 99spaded 99-04 21 October 7th, 2008 05:23 PM
starting problem 88stang 5.0 Mustangs 3 August 12th, 2008 08:02 PM
problem starting mustangman0001 5.0 Mustangs 3 March 4th, 2007 01:52 PM
