AOD shifting problem
LinkBack (1) Thread Tools
Old February 23rd, 2011, 02:22 PM   1 links from elsewhere to this Post. Click to view. #1
PhillyGT's Avatar
2001 Mustang GT
13.8@101.58mph!
PhillyGT is on a distinguished road
Please before anybody says swap it to 5speed i need real help.I pulled outta my driveway and it wouldnt shift into 2nd or 3rd.So i pulled right over and check my fluid,and it read that it was overfilled?Before this happened i was hearing a whining sound coming from the tranny like it was running low.So i put a QT in it,and BAM it starts shifting fine???Also my check engine light came on??I also cant get a proper reading on trans stick?
Dropped on Eibachs,K&N FIPK,Mac-prochamber o/r,Flowmasters.Short throw,Heavy Right Foot Mod
Old February 23rd, 2011, 07:25 PM   #2
PhillyGT's Avatar
2001 Mustang GT
13.8@101.58mph!
Ok update I let it run for about 10 minutes.I tried adjusting the tv cable and itll shift very erraticlly now.Now im not sure if its shifting cause i adjusted it or cause its warmed up.Im gonna change filter and fluid tomorrow.Anybody else with same problems?
Old February 25th, 2011, 04:34 PM   #3
Ohsplat's Avatar
1983GT
No motor or trans
Ohsplat is on a distinguished road
Send a message via Yahoo to Ohsplat
It is the SAME problem I was having last week. I had to pull the valve body out and I had 2 valves that were worn and sticking.
My problem started with NO overdrive, the it would not shift out of 3rd. Then when cold would not come out of 1st unless i let off throttle. After it warmed up all was fine except still no OD.
The OD valve had worn into the sleeve it sits in. Both are replaceable. The 1st gear valve was gummed up. I just ordered a whole new valve body. Not to hard to install while the trans is still in the vehicle.
Old February 25th, 2011, 06:55 PM   #4
PhillyGT's Avatar
2001 Mustang GT
13.8@101.58mph!
Yeah after it warms up itll shift,but not at the right shift points,and it felt like OD was slipping.Im gonna change the fluid tomorrow and try to clean it up and check if anythings gummed up.Also this shit just started all of a sudden the other day with no warning.
Old February 25th, 2011, 09:49 PM   #5
Ohsplat's Avatar
1983GT
No motor or trans
Yep it was the same for me. Started after I floored it one day and shut it off. The next day it had the issues. Doubt a fluid change will help, if you look on youtube you can find a video of a guy explaining how to remove and install a valve body on a ford aod. Its really not that hard with the trans in the car. You just have to make sure you hook the linkage back up.
Reason i doubt the fluid change will help is because if a filter is dirty.. its dirty hot or cold. Your probably just wasting money on more fluid. Im willing to bet the valve is trashed like mine was.
Old February 26th, 2011, 11:50 AM   #6
PhillyGT's Avatar
2001 Mustang GT
13.8@101.58mph!
Your probably right.Im gonna open it up and check it out though
LinkBack to this Thread: http://www.moddedmustangs.com/forums/5-0-mustangs/205518-aod-shifting-problem.html
Thread AOD Issues...Not shifting correctly and no 3rd gear. | Mustang Forums | AllFordMustangs.com | BoardReader This thread Refback September 6th, 2011 09:38 AM
Threads Similar to: AOD shifting problem
shifting problem adrian0475 2005 - 2010 35 November 5th, 2010 05:13 PM
Shifting problem....stumped Dunbar 4V / SVT 8 May 24th, 2010 11:40 AM
93 5.0 shifting problem redstang9136 5.0 Mustangs 3 May 9th, 2010 05:28 PM
automatic shifting problem V8POWA! 96-98 11 March 29th, 2010 11:24 PM
shifting problem 96 gt gtdan 96-98 0 July 17th, 2006 06:09 PM
