89 gt clutch question
Old February 23rd, 2011, 06:29 PM   #1
1989 mustang gt
Trfd5.0 is on a distinguished road
Is there any way to tell how many splines my clutch has with out pulling the trans out???
Old February 23rd, 2011, 07:15 PM   #2
1989 mustang lx
89lxstang5.0 is on a distinguished road
Send a message via AIM to 89lxstang5.0
with out seperating it.. no. why do you need to know how many splines your clutch has? jc
Old February 23rd, 2011, 08:11 PM   #3
1989 mustang gt
Cuz My clutch is slipping at high rpms in 5th gear so I'm gunn a have to change the clutch I think and there are two different splines for that year
Old February 23rd, 2011, 08:50 PM   #4
1989 mustang lx
i could be wrong but i believe there all ten spline... only way i could see it being any different is u had a different trans other then a t-5
Old February 23rd, 2011, 09:13 PM   #5
1989 mustang gt
All the books show it could be a 10 or a 26
Old February 23rd, 2011, 10:16 PM   #6
1995 Mustang GT
Bubba95SN is on a distinguished road
Unless someone replaced the stock parts, the spline number is 10.
Old February 23rd, 2011, 10:25 PM   #7
1992 Lx
11.39@119.24
Old February 23rd, 2011, 10:26 PM   #8
1992 Lx
11.39@119.24
and thank me later
1986-1995 Ford Mustang King Cobra 10.5" Clutch Kit Package - UPR-M-7560-C302 - UPR Products
Old February 23rd, 2011, 10:43 PM   #9
1989 mustang gt
Thanks
Old February 23rd, 2011, 11:50 PM   #10
95tbirdv8's Avatar
1990 mustang gt
95tbirdv8 is on a distinguished road
Before you get the clutch check if there is oil in the bellhousing, happened to me
Burning Rubber in the 5.0
http://www.youtube.com/watch?v=mKGSmRkKQcM95
95 mark8 lsc 95 tbird v8 90 mustang gt 07 silverado v8 08 yamaha r6
to be continued........
foxbodyperformance.com is the way to go
Old February 24th, 2011, 12:43 PM   #11
1990 Mustang Gt
redgt90 is on a distinguished road
I'm doin a clutch right now in mine, its a 1990, and its a ten spline. Andd... there is oil in my effin bellhousing.. rear seal leak maybe?
Old February 24th, 2011, 12:48 PM   #12
95tbirdv8's Avatar
1990 mustang gt
either that or the oil pan gasket. when my clutch went out i replaced it along with the flywheel, pilot bearing, and rear main seal. some months later it started slipping in high gears at higher rpms. my oil pan gasket was letting oil into the bellhousing. good thing i took it off first before buying a new clutch
Old February 24th, 2011, 12:49 PM   #13
1990 Mustang Gt
hmmm, good to know. Dont wanna screw my new clutch up.... replace the oil pan gasket you think?
Old February 24th, 2011, 01:21 PM   #14
95tbirdv8's Avatar
1990 mustang gt
i would find out where its leaking from, cause its hard to change the oil pan gasket. its common on these cars for the rear main seal to leak
Old February 24th, 2011, 10:10 PM   #15
1990 Mustang Gt
...great :p
Old February 24th, 2011, 11:09 PM   #16
1992 Lx
11.39@119.24
75% of foxes have a leaky oil pan gasket. Youre gona change it and its still gona leak
Old February 25th, 2011, 09:57 AM   #17
1990 Mustang Gt
Also good to know. Thanks man. I'm thinkin just use some silicone or somethin and gum some in there in a few spots.
Threads Similar to: 89 gt clutch question
Clutch question okstangpede 99-04 4 December 24th, 2010 06:38 PM
clutch question StutteringStang06 2005 - 2010 16 March 26th, 2010 03:47 PM
clutch question adrenaline=lifeline 99-04 3 May 13th, 2009 01:19 AM
clutch question supermachone 99-04 16 October 21st, 2008 02:05 AM
Clutch Fan question 1sl0w88 5.0 Mustangs 5 September 2nd, 2008 12:34 PM
