'82 Mustang GT
Bad Vibration starting at about 30 mph.
Hey, all. I'm new here, anyway heres the question. I bought an '82 mustang gt, that has already been modified. One of the relevent mods, is that it has sub-frame connectors. Apparently it used to sport a blower and pull wheelies, and was heavily thrashed at the local drag strip. It runs and drives, but needs TLC. One of the things wrong, is that when you get going up to 28-30 mph and beyond, the car shakes bad. You can feel it in the steering wheel real bad, and see the dash vibrate. Its pretty severe.
Does any one think they know what this is? I want to find out before I put a new engine in it. The guy who sold it to me said he thinks its in the front end, from a hard wheelie landing. Even though it has sub frame connectors, it has t-tops. Could the frame be bent? Bent drive shaft? Thanks, Paul |
89 FOX/01 WS6
0@0/13.1@106
If it is only at 30mph and up I would think it could be a number of things.
Driveshaft, bent wheel(s), bad tire, bad/broken/loose suspension part |
'82 Mustang GT
Yeah, I figured. I've had the front wheels off, to replace the calipers, and did a quick visual check of the suspension, and nothing looked loose or bent. Front tires are brand new. And I assume balancing would detect a bent rim. How common are bent driveshafts? Could a bent frame cause a severe vibration? I think it has to be in the front of the car because of how bad the steering wheel shakes. That would eliminate a bent drive shaft.
89 FOX/01 WS6
0@0/13.1@106
how about front wheel bearings? when the car was jacked up did the wheel have alot of play?
'82 Mustang GT
no I dont think they did. I think they were fine, I'm gonna check again though to be sure. Can a wheel bearing make a very severe vibration, because I've heard bad wheel bearings, and its nothing like this. This is maybe 10 times as severe as the bad wheel bearings I've heard.
I think I'm just gonna tear the whole front of the car to pieces, and put a new k-member and coil overs, etc. If I replace everything, I'll be good. Gosh Darnit. |
'82 Mustang GT
maybe a bent hub?
89 FOX/01 WS6
0@0/13.1@106
A hub is a non servicable unit. The foxbody has spindles with replaceable wheel bearings. Newer vehicles use hubs. If they go bad you have to replace the whole assembly.
93 Mustang Gt
My moms truck had the same problem and it was the tires. They were also new, but we replaces them and it doesn't do it now.
'82 Mustang GT
Ok, thanks.
1990 GT
unknown
Never had any issues with the fox but my Jeep had a terrible wobble, I rotated the tires front to back and it cleared up. Granted that was with 37" tires, but it may be worth a shot.
1990 ford mustang GT
usually a bad wheel bearing would make a growling noise when it's bad. what u can do is jack the front end of the car, shake the wheel side to side, and then up and down. If that's ok, spin the wheel of our front end tires and look at it head on. see if the wheel spins straight. make sure the tire balance is correct. hopefully it's that because that's the cheapest fix.
sometimes when u have a bent twisted frame, your door is a little bit cockeyed and your door doesnt' close smoothly. i had one guy came to the shop with a obvious bent subframe. his door didn't close right and his car was shaking like hell. |
'82 Mustang GT
Thanks bennyjet846. Thats kinda what I was thinking, thanks for confirming that stuff. Also, how badly was that guys door askew? My driver door closes rough, but I think the hinge is just loose from it being 29 years old. And I do have sub frame connectors, so it would be very unlikely to have a bent sub frame right?
Anyway, thanks again! - Paul |
#13 | |
Check shocks \ struts for wear . Most likely though it might be the drive shaft , I ahd that problem with my stang. Had a serious virbration like you speak off , it ended up that the drive shaft was cracked & bad u joints. I replaced mine with a alumium drive shaft & heavy duty u joints. ![]() Forgot to add , see if your tires have been balanced too. Good luck , keep us posted on the outcome.
Have you driven a Ford lately ?
Threads Similar to: Bad Vibration starting at about 30 mph.
| vibration | Ryguy33 | 99-04 | 13 | December 29th, 2010 09:35 PM |
| Vibration in 5th | AndrewA. | 99-04 | 1 | December 3rd, 2010 06:53 PM |
| Starting, dying, not starting.....WTH?? | shadowgames81 | 5.0 Mustangs | 6 | October 7th, 2010 09:40 AM |
| Mad vibration | 95project | 5.0 Mustangs | 21 | November 28th, 2009 10:22 PM |
| Vibration | graystang01 | V6 Mustangs | 21 | December 15th, 2007 11:23 PM |
