1986 5.0 GT 5 Speed Steering Column HELP
Old February 26th, 2011, 07:15 PM   #1
1986 Ford Mustang GT
Unknown...
1986_Stang_GT is on a distinguished road
So,
I am new to the forum so I figured I'd start with my question about my clomun swap in my recently purchased 86 GT. I am replacing the old worn out, wobbly, and stupid tilt wheel that i have in it now with a non tilt column from an 87-89 Mustang.. I have the column all dropped, everything INSIDE the car is done.. But on the engine bay-side of the firewall at the bottom of the column there is a bolt that holds it in place with the connecting piece (Resembles a small U-Joint) and i cannot get the bolt off.. :'( Didn't know if you all had any tricks/tips/ideas on how to get this off? There's nearly no room to get any pipe on the end of my ratchet for leverage also.. So i don't know what to do anymore! PLEASE HELP!
Old February 26th, 2011, 07:20 PM   #2
fogged306's Avatar
89 GT
If you're talking about the clamp for the rag joint, then either put enough extensions on your socket wrench so you can get the wrench itself out far enough to put a piece of pipe on it, or you can soak it in penetrating oil and let it sit for a while and try again. Or you can apply heat. The problem is that you'll probably burn your rag joint if you hit it with a torch for long enough to loosen the bolt. If you're replacing that too, then it doesn't matter.
Old February 27th, 2011, 02:45 AM   #3
Unknown...
Yes thats the right part..
Well i guess i have only the extention or oil option.. I might be able to get an air tool from a friend to borrow, see if i can break it loose, but i dunno. ill try the oil trick first.
Old August 7th, 2011, 09:25 PM   #4
Look Ma! My First Post!
marzmustang is on a distinguished road
did you get it to work? curious does 87 -89 work in a 86? I hope so!
Old August 7th, 2011, 09:36 PM   #5
The Big Spoon
jessemachone's Avatar
88 5.0 5 Speed Notch <><
never fast enough
jessemachone is a glorious beacon of lightjessemachone is a glorious beacon of lightjessemachone is a glorious beacon of lightjessemachone is a glorious beacon of lightjessemachone is a glorious beacon of light
i have an 88. my column wobbled bad. I was going to swap it out w one from a 92 but i took the covers off my column in the car first to see what was up. turns out, all I had to do was tighten 2 7/16-ish bolts on the left side of the column. it was as easy as that. check it before you wreck it!
Black Stang Crew
Originally Posted by 302Army187 View Post
old 5.0's are like a box of chocolates.......... never know what your gonna get
Old August 8th, 2011, 10:16 AM   #6
cleangtvert's Avatar
1991 gt vert
cleangtvert will become famous soon enough
87-89 has tilt wheele no air bag. 90-93 has non tilt w/air bag
Old August 8th, 2011, 05:37 PM   #7
The Big Spoon
never fast enough
I don't know if you were posting at what I wrote but I do understand that. I was just presenting the case that it may be a simple fix like mine was. Mine wobbled like crap as well. I as shocked that it was just a matter of tightening up a couple of bolts.
Black Stang Crew
Old August 8th, 2011, 11:49 PM   #8
ryanw's Avatar
1991 Ford Mustang GT
In my old 85 gt my column was sloppy and i just tightened up two bolts and it was fine ( i think they were star headed bolts, but that was a really long time ago)
Trick Flow R intake,
jba headers, 2 1/2" x pipe
flowmaster super 10 mufflers,
255 fuel pump,
3:27 gears
Old August 9th, 2011, 04:59 AM   #9
The Big Spoon
never fast enough
Mine were hex. I wanna say 10mm. ah the glorious time when cars were half sae and half metric.
Black Stang Crew
Old August 9th, 2011, 10:43 PM   #10
ryanw's Avatar
^^I hear ya, lol............ and i think your right about them being hex
255 fuel pump,
3:27 gears
Threads Similar to: 1986 5.0 GT 5 Speed Steering Column HELP
98 steering column in a 95 tango7 General Tech 2 February 13th, 2011 08:03 PM
steering column jessemachone 5.0 Mustangs 3 June 3rd, 2009 07:24 AM
Steering Column 99stangman V6 Mustangs 5 November 17th, 2007 06:56 PM
