Turbo 5.0 goes to WOT by itself. - Page 2
Old March 3rd, 2011, 09:59 PM   #21
nurkvinny is on a distinguished road
Ha, now if I can ever find a spare hour to get back out to the garage...
Old March 4th, 2011, 12:19 PM   #22
badshoe is on a distinguished road
An IAC that's mounted backwards can cause it. The wire connector should face the air filter side of the throttle body.
BadShoe Productions, How-To-DVD's specializing in Ford drivetrains www.BadShoeProductions.com
Old March 4th, 2011, 02:44 PM   #23
This is an old picture from a previous owner. The engine bay has been MUCH improved since this pic, but it shows the orientation of the IAC...
Old March 5th, 2011, 02:33 PM   #24
So...
Unbolted the TPS again, realigned and rebolted.
Removed IAC, cleaned with TB cleaner, reinstalled.
Checked all vacuum lines a third time.
Started it up, idled out into driveway, sitting in place shifted between N, R, and 1 repeatedly, revved to all different RPMs while in gear and not.
Vacuum showed 13-20 depending on engine speed and held steady when engine speed was constant. Stumped on brakes hard a couple times to rule out bad booster.
Car does have a very noticeable stumble while tapping the throttle from an idle. Falls on its face when you floor it. Cap and rotor look shitty, will clean them up. Plugs look good, same for wires.
Car idles high, IMO, about 1000-1250, but did not experience WOT issue.
Think the TPS could cause the stumble, high idle, etc?
Thanks.
Old March 5th, 2011, 07:39 PM   #25
1992 Lx
11.39@119.24
yup
Old March 6th, 2011, 01:28 PM   #26
New TPS installed just now. Things were 75% better. No idle surges. Was able to goose the pedal right after starting it and it responded tons better.
Still some hesitation now though after it ran for a minute or so. Maybe there is a learning period or something like that when you replace the TPS?
Old March 6th, 2011, 02:32 PM   #27
Found the re-learning procedure. Doing it shortly.
Old March 6th, 2011, 02:58 PM   #28
1992 Lx
11.39@119.24
you set the voltage right
Old March 6th, 2011, 04:49 PM   #29
Yes. I got a .98
Old March 10th, 2011, 08:07 PM   #30
Hasn't surged since.
Traded the turbo 5.0 BMW for a beautiful 89 Fox.
Threads Similar to: Turbo 5.0 goes to WOT by itself.
Dyno results from new CEA 67mm Billet Turbo from Precision Turbo 499whp 552wtrq 13psi Turblow 99-04 18 November 9th, 2010 09:12 PM
Turbo timers and Boost Controllers? Turbo guys where you at? 95StangSVT General Tech 14 July 11th, 2008 07:01 AM
Mellon's Twin Turbo Stealth vs Wills99z's Single Turbo z28 Mellon Videos 10 December 30th, 2006 10:05 AM
Super Charger vs Turbo/Twin Turbo: Pros and Cons of each FireryDriver 2005 - 2010 9 September 17th, 2006 04:15 PM
