Turbo 5.0 goes to WOT by itself.
I have an 89 5.0 with Cobra intake, GT40 heads, good valvetrain, stock cam and bottom end and a 72mm turbo setup using a C4 trans. Aftermarket throttle body, but unsure of brand or size.
Twice now, once while idling in reverse and once while idling in drive, the car went from idle RPM to 5500-6000rpms by itself. I've seen cables stick open, but I was not revving it beforehand, just idling. Something caused the RPMs to raise and stay at WOT until I killed the ignition. Any ideas of a possible cause would be appreciated. Thanks guys. |
2003 mustang
7.48x1.56=11.67
idle air control could be the only thing i can think of. clean or replace it
New combo: Forged SC short Block,280cfm heads, Precision 6262 turbo, cx 31x12x3 fmic ![]() ![]() http://photobucket.com/JTsTurboBuild http://youtube.com/user/JTsStang |
1989 Mustang GT 5.0
damn thats scary i hope u have an MSD 6AL box or some kind of rev limitor
Cage Maximum Motorsports Sparco QH/BE Nitto "a huge bad azz motor is nice untill you have to turn or stop" |
1991 Mustang LX 5.0
I'm gonna go with a ghost. Did a previous owner die in your car?
Point made in less than a few hours with minimal response. http://www.moddedmustangs.com/forums...ml#post4465184 |
My old 1990 GT did the same thing, it was my cruise control going crazy. I unhooked the CC cable and problem solved. Hope this helps.
1990 LX 5.0 2000 Expedition 2002 Honda Accord One tea cup Chihuahua guard dog!!!!!!! |
LOL, sorry i couldnt help. Keep us posted!
Verified gas pedal movement, no binding.
Strong return spring rate, nothing in its way. The only odd thing I can find is that the inside of the TPS looks all buggered up. |
1991 Mustang LX 5.0
Any sign of ghosts?
1992 Lx
11.39@119.24
tps. My car did the same thing. Yes your tps can pull the car to 6k with the tb closed. Dont ask me how
I would check out everything around the throttle body as mentioned 1st. May be far fetched but just a thought here even though I dont think I have heard of this happening but may be a possible cause, if something is causing the blowoff valve to close at idle & starts building boost that forces the TB open & engine to rev.
#13 | |
Thanks |
KB'd GT
It wont rev that high without boost, or an open throttle body. A vacuum leak would be there all time. As suggested watch your boost gauge when it happens to rule out wastegate issues.
My failing TPS caused mine to randomly jump to at least 3-4K with the throttle plate closed. Seems like it could have just as easily went higher. Logically, you do need air from somewhere to support that but it was doing it and seemed like it could have gone higher. My intake on that car is completely stock but a lot of people with boost have a breather and the PCV or some type of seperator, maybe it sucked supporting air through that.
#16 | ||
89 GT
1992 Lx
11.39@119.24
ignore the slow cranking this was when I first got the car back together. This is what my bad tps did
click it its a video
Thanks for posting that. Add 1500-2000rpm and that could have been filmed in my car.
![]() I did find an obvious vacuum leak last night. PCV line was not plugged in. Car is open exhaust and it was too late to fire it up and see what kind of difference that made. I can't believe that the PCV by itself is responsible. |
Atomized
tps no doubt. Proofs in the pudding
spray and pray |
My fox used to idle at 2k , runs out of breath almost dies then spins up to 2k again. This would happen every time i started her up after a long time parked. Turned out it was a dirty iac. After cleaning it up i saw improvements. I dunno, maybe your iac is seveeerely clogged up or something. as previously stated vacuum leaks should be checked for as well.. Here's a vid i took back when the engine would act silly
Threads Similar to: Turbo 5.0 goes to WOT by itself.
| Dyno results from new CEA 67mm Billet Turbo from Precision Turbo 499whp 552wtrq 13psi | Turblow | 99-04 | 18 | November 9th, 2010 09:12 PM |
| Turbo timers and Boost Controllers? Turbo guys where you at? | 95StangSVT | General Tech | 14 | July 11th, 2008 07:01 AM |
| Mellon's Twin Turbo Stealth vs Wills99z's Single Turbo z28 | Mellon | Videos | 10 | December 30th, 2006 10:05 AM |
| Super Charger vs Turbo/Twin Turbo: Pros and Cons of each | FireryDriver | 2005 - 2010 | 9 | September 17th, 2006 04:15 PM |
