1989 Mustang GT 5.0
lil help on removing front struts
what size wrench do i need to use on the top of the strut that holds the strut from rotating when u try to loosen nut on strut, i have to go buy this wrench cuz i dont own one...
also any tips on removing spindle bolts...(im using a breaker bar and pbblaster) and these things AINT MOVING....god damn i need air tools im guessing 5ft pipe on breaker bar for more leverage...? or maybe heat them up with torch?
Cage Maximum Motorsports Sparco QH/BE Nitto "a huge bad azz motor is nice untill you have to turn or stop" |
91 LX Hatch
21 mm for the nut.
Typically you can apply more torque with a good size breaker bar than most run of the mill impact wrenches. |
1991 Mustang LX 5.0
Lefty loosey, righty tighty
Point made in less than a few hours with minimal response. http://www.moddedmustangs.com/forums...ml#post4465184 |
1989 Mustang GT 5.0
#5 | |
1989 Mustang GT 5.0
I have a wrench for the nut, i need a wrench for the top of the strut the boxed part so i can hold strut while i loosen nut
1991 Mustang LX 5.0
91 LX Hatch
91 GT 90 LX 5.0
I think i ended up heating it up and using a vice grips and an impact wrench and it was enough to break it loose
1991 GT- All Stock 1990 LX 5.0- CAI, Shorty headers, flowmaster, Tubular Upper and Lower Control arms, Tokico HP series, Eibach Springs |
#9 | |
1989 Mustang GT 5.0
yes on the top of the strut, (threaded part) top of shaft there are two flat sides that u hold with a wrench while u loosen the nut, i need to find out the size of the wrench, im using a 7/16 wrench and its just a lil to big
1991 Mustang LX 5.0
Try 10mm? Or crescent if you have to.
1969 Mustang Mach 1
6.824@101.61
There's always a hacksaw
./___ _ ____ ___ \. ( ]]] _ _ O _ _ [[[ ) \_ o _ _____ _ o _/ |___| ......... |___| http://www.youtube.com/watch?v=HyYU3...e_gdata_player |
1989 Mustang GT 5.0
1989 Mustang GT 5.0
ok so the top of the shaft is a 10mm,
what i need is a double D socket so i can loosen the nut...or an impact gun... got the bottom two bolts out of strut/spindle (love blow torches)
1992 Lx
11.39@119.24
<------------built in breaker bars
1991 gt vert
one of my best tools in my arsenal is my can of M.A.P.gas (yellow one)and a $10 dollar torch head from the plumbing section @home depot! if you doint have one get one. nice simple way to get stubborn bolts/nuts off.
'89 LX 'Vert
10's or bust... Literally.
dang hatch, how many times a day do you jerk off to get arms like that?
H/C/I 302 + nitrous for now... supercharger/turbo soon? ![]() |
#17 | |
'89 LX 'Vert
someday I will have enough money for proper tools around this SOB
1991 gt vert
it's not as good as a O/A set up ,but its small and will get most jobs done. i've gotten spindle nuts and fine thread axle U-bolts off with just the MAP gas torch on my old 4x4's. you can even buy the head and a can of gas at autozone.home depot or lowe's will be a bit cheeper. under $30 bucks. after you use it to get just one bolt you will have saved the 30 in agravation and broken tools! if its a nut you heat the nut,and if its a bolt you heat the part it threads into.. it woint get hot enough to make it glow. you would need O/A for that, but if you keep it on their for two-three minutes it will kinda have glowing speckles in the metal.then it's ready. doint get propain(blue can) get the yellow one map is hotter
Strut bolts are easy.. Use a giant fucking flat head screw driver and put it in the top slot of the nut. Have someone else put the proper size wrench on the strut and turn that shit.
If you use vice grips and shit you'll end up having to replace the strut |
1989 Mustang GT 5.0
got em out!
i have a yellow torch (helps alot) bought a gas generator today and used my buddies electric impact GUN took SECONDS im buying an electric impact gun, things saves HOURS!
Threads Similar to: lil help on removing front struts
| Removing front sway bar | lilspanky9119 | 96-98 | 15 | October 15th, 2010 01:02 PM |
| Front Struts ?? | I8ACMRO | 99-04 | 8 | May 27th, 2010 02:02 AM |
| Front Struts | usafimj | 2005 - 2010 | 14 | April 16th, 2009 08:57 AM |
| Front struts | imported_Gt_Jay | 5.0 Mustangs | 3 | November 19th, 2007 02:02 AM |
| front struts? | db83stang | 5.0 Mustangs | 7 | March 18th, 2007 11:35 AM |
