question about "big" intakes... - Page 2
Old March 3rd, 2011, 04:59 PM   #21
horsepowerjunkie's Avatar
1989 Black LX---Turbo
horsepowerjunkie will become famous soon enoughhorsepowerjunkie will become famous soon enough
Takern directly from Fox Lake FAQ:
What are the major differences between the Trick Flow Street Heat, Track Heat, and "R" intake manifolds?
While the Street Heat and Track Heat intake manifolds use the same exact lower, the upper on the Track Heat has runners that are 3" shorter inside the manifold. While they look identical from the outside, the Track Heat is more suited for forced induction or higher RPM applications and the Street Heat is more suited for idle-5500 RPM applications. The "R" intake is definately more of an intake for high RPM or large cubic inch motors. The "R" intake is not designed for a 302 cubic inch motor unless it is used with 15+psi boost.
89 LX Black, Boss 331, C4,T76BB, FAST EFI
82 Capri RS,89 5.0 HO,Comp XE266,TW 170,T5,etc.
73 Dart Sport 340, 410ci Bracket Brawler
72 Demon 340 4-speed 1 of 1667
01 Ram Quad Cab
03 Grizzley 660
Old March 3rd, 2011, 05:36 PM   #22
302Army187's Avatar
'89 LX 'Vert
10's or bust... Literally.
302Army187 has a spectacular aura about302Army187 has a spectacular aura about
hrm, maybe you don't know by build well enough. haha.
the intake will do just find. I just had my mind racing about this new build....
I'm more then likely picking up a "kit" on Saturday that will make the motor split with epicness at the very use of it.
it will make the motor go from 330rwhp to about 550rwhp at the press of a few buttons.
*nudge nudge*
H/C/I 302 + nitrous for now... supercharger/turbo soon?
www.youtube.com/Xarmy187
Please support my YouTube channel! My videos don't disappoint!
Old March 3rd, 2011, 07:12 PM   #23
1992 Lx
11.39@119.24
lol at trickflow r and 15 lbs boost
Old March 5th, 2011, 05:02 PM   #24
tmoss's Avatar
tmoss is on a distinguished road
I've seen this supposition that when running lots of boost, you need a larger intake. Well, like any other aspect of racing, there are no hard and fast rules - I know of a YSi blown 331 running 8.70s using a ported RPM1 that tried a TFS-R Box with a Kurgan tune after guys told him he'd go faster and he finally reached the power or ET of the smaller intake after the tune on the Box by Bob Kurgan, so put the RPM1 back on and went quicker/faster than ever. I tried posting the screen capture of the story but I can't get an upload anywhere on this site, an attachment to the post, in the gallery, etc - I must be banned from it. No loss of mine...........
88 GT Vert 5spd, 3:73 gears, Explorer intake/65mm TB, Explorer Ps, Manley race 1.85/1.55 valves, 1.7/1.6 stud rockers, stock cam +4 degrees, MAC Jet-Hot coated shorties. 277RWHP/330RWTQ www.fastlanecars.com http://tmossporting.0catch.com/
Old March 5th, 2011, 05:05 PM   #25
302Army187's Avatar
'89 LX 'Vert
cool!
yea, boost change's everything. I remember reading a article how 99% of intakes are designed to PULL air through them, while a blower/turbo are FORCING the air in. so all kinds of crazy things can happen.
Threads Similar to: question about "big" intakes...
Is your husband basically more "Urban" or "Rural" ? Forked Tongue The Clubhouse 3 January 2nd, 2011 08:43 AM
The Infamous "Cluster-Swap" Question... Lefty Audio/Video 13 September 24th, 2009 06:47 PM
Pulled Cobra Question-"NOISE" ZOOTOXIN 4V / SVT 3 July 6th, 2008 11:24 AM
the "TV" cable on my 88 popped off, how to adjust? (trans question) 78mach1 5.0 Mustangs 14 June 17th, 2008 02:44 PM
QUESTION....Pro Chamber and the dreaded "drone" Bossman 2005 - 2010 9 February 26th, 2007 09:14 PM
