'89 LX 'Vert
10's or bust... Literally.
question about "big" intakes...
So I might be changin' a few things up. don't want to say to much, as the "deal" im getting might fall through.
But part of it is a edelbrock Victor 5.0 intake upper/lower. I think the lower has been ported a bit. I was told it was opened up, and it looked it, but no recipts or proof of said job. I have a typhoon right now. I had been planning on keeping it, as I paid to have the lower ported out pretty good a while ago, and I ported the upper a bit myself. Just opening up the throttle body mounting area, and then cleaned out all the extra crap in the intake runners. Peak power will be 5,700-6,300 ish, so nothing wild.... still a 302 also. So is the edelbrock victor going to be over kill? even with the porting of the typhoon, im sure the victor will have a big jump in power over 5,000 rpm. probably even sooner, like 4,500. but as far as anything lower then that, am I going to lose a ton of power from 4,500 and under? I know on good set ups losing low down poewr is a joke. but with my off the shelf BS cam, I am a little worried, but that might be going away soon too..... Just want your guys thoughts. I will probably go ahead with the deal ether way, but just got my mind buzzing about the change. Rob
H/C/I 302 + nitrous for now... supercharger/turbo soon? ![]() Last edited by 302Army187; February 28th, 2011 at 08:10 AM. |
1992 Mustang LX
13.0 @ 105
Ditch that typhoon and grab the fuckin victor. All day. 1slo5.0 used a victor 5.0 with almost the same setup as you. Except he had the stage 1 cam, not the stage 2.
As I lay rubber down the street I pray for traction I can keep But if I spin, and begin to slide Please dear God, protect my ride |
to big for what? what heads do you have? cam? etc.
i am running a fully ported victor5.0 and 185cc heads with a high lift low duration cam on a stock shortblock. |
'89 LX 'Vert
its not that I don't think it will work. its more so that im just thinking about the new set up a lot, haha.
I know people run big intakes, or box intakes with great success, but the only builds I know of are normally with really good parts, like 93hatch's custom cam, ported heads, and a 347. which is in a whole other ball field compared to my set up. my set up for those that done know is: rebuilt explorer motor 302, mildly ported track heat twisted wedge o-ringed heads, and for now.....off the shelf stage 2 cam, a typhoon intake, ported a bit, like stated before. full bolt on's, electric fan, a/c and emissions delete, aluminum driveshaft, 4.10's blah blah blah.
H/C/I 302 + nitrous for now... supercharger/turbo soon? ![]() |
1992 Mustang LX
13.0 @ 105
Fuckin do it. Don't pussy foot with that typhoon anymore. Dump it, and grab that victor for sure. It'll be good with your setup.
'89 LX 'Vert
like I said, as long all the other parts look good, and not wore out, im defiantly getting everything.
has two seasons of racing on the parts im buying, but the car ran a 10.8 as a best past, and consistent 11.2's at my elevation when dialed back a little to be consistent. I hope to replicate the same. (which would be mid/low 10's at sea level) I'll revel the parts come Saturday, if I end up buying them.
1992 Mustang LX
13.0 @ 105
Damn...Now I wanna know what they are.
1991 Ford Mustang GT
+1
come on just tell us what the other stuff is that your getting
'89 LX 'Vert
loose lips sink ships!
1991 Mustang LX 5.0
So do cannonballs
Point made in less than a few hours with minimal response. http://www.moddedmustangs.com/forums...ml#post4465184 |
'89 LX 'Vert
I'm planning on walking softly and carrying a big stick
1992 Lx
11.39@119.24
only do it if youre gona have it milled to fit your heads. That intake lines up HORRIBLY to tf heads out of the box. Good 302 intake
#13 | |
'89 LX 'Vert
I heard about them not lining up to AFR heads. thanks for the heads up. You know of a place that can do this? IDK anyone local that I would trust even for something this simple :/
1992 Lx
11.39@119.24
measure it yourself and tell the machine shop how much to take off
'89 LX 'Vert
not sure how...
just lay it on the heads on the motor, and use a feeler gauge?
1992 Lx
11.39@119.24
I dunno how lawl thats what my friend did
1992 Lx
11.39@119.24
one more thing if the ports on the lower are opened up dont buy it. Once an intakes been fucked with to someone elses application or more than likely just some idiot opening shit up, youll never get it to line up. Mine was bigger than my heads and my intake port on my heads is a 1262 gasket, the victor would never have lined up with my heads so i ditched it
'89 LX 'Vert
well when I eye balled it, it just looked polished/cleaned up, not all hogged out. so I think I will be fine.
1969 Mustang Mach 1
6.824@101.61
Any nimrod at a machine shop should be able to true the surface up for you.
./___ _ ____ ___ \. ( ]]] _ _ O _ _ [[[ ) \_ o _ _____ _ o _/ |___| ......... |___| http://www.youtube.com/watch?v=HyYU3...e_gdata_player |
#20 | |
'89 LX 'Vert
i got one reliable guy I trust, but I think he only works on cylinder heads. I'll call him up first, because I trust his work, and he has a quick turn around.
Threads Similar to: question about "big" intakes...
| Is your husband basically more "Urban" or "Rural" ? | Forked Tongue | The Clubhouse | 3 | January 2nd, 2011 08:43 AM |
| The Infamous "Cluster-Swap" Question... | Lefty | Audio/Video | 13 | September 24th, 2009 06:47 PM |
| Pulled Cobra Question-"NOISE" | ZOOTOXIN | 4V / SVT | 3 | July 6th, 2008 11:24 AM |
| the "TV" cable on my 88 popped off, how to adjust? (trans question) | 78mach1 | 5.0 Mustangs | 14 | June 17th, 2008 02:44 PM |
| QUESTION....Pro Chamber and the dreaded "drone" | Bossman | 2005 - 2010 | 9 | February 26th, 2007 09:14 PM |
