#21 | |
Authorized Vendor
![]() 2007 Mustang GT
We can definitely set up the tune for the injectors, without having to use a MAF sample tube to skew the incoming airflow. You set the base timing to 10 degress btdc and we do the rest!
Chris Rose | AmericanMuscle.com Toll Free: 866.727.1266 | M-F 9AM-9PM EST | Sat 10AM-4PM EST Bama Hotline: 888.226.9764 | M-F 9AM-5:30PM EST | Sat 10AM-4PM EST Need Help? PM AMShaneLesky for immediate assistance! |
#22 |
What about for a h/c/i swap like gt40 heads, cobra manifold, anderson cam ext.....
Is there even a tune to be had...? Also say i have my timing bumped to 14 degrees is that chip gonna mess something up wtih that? |
#23 |
89 GT
There's always a tune to be had, even with a stock setup you can improve on it. May not be much, but it still has room to grow. If you get a chip or a tune, you always want to set the timing back to 10*. The chip will take care of the advance for you so there's no need to set it higher because all it will do is screw up the timing curve of the tune.
#24 |
1990 Mustang GT
I don't know jack $h1t about fuel systems. So when I'm done upgrading my ignition and electrical system what all components are in a fuel system other than the pump, filter, injectors and some highflow fuel rails? Also when should I get 24lb injectors?
#25 | |
Authorized Vendor
As for the head swap and all, yes you would greatly benefit from dialing it in a little better.
Threads Similar to: Stack Racing C.A.I. & SCT Chip???
| Stack Racing C.A.I. & SCT Chip??? | bioberg | 5.0 Mustangs | 0 | February 28th, 2011 01:18 AM |
| Stack Racing | rpetty | 96-98 | 11 | December 4th, 2010 11:04 AM |
| stack racing?? | zarcit | V6 Mustangs | 9 | July 11th, 2010 03:29 PM |
| Stack Racing Plenum help | BlackedOut04GT | 99-04 | 34 | May 10th, 2010 07:47 PM |
| STACK racing products ?? | SilverGT04 | 99-04 | 6 | December 15th, 2009 05:54 PM |
