Cobra or HO wont start
Old March 1st, 2011, 10:14 PM   #1
SCMBOB is on a distinguished road
ok i bought a 91 mustang with a supposed "COBRA" swap!! so as excited as i was i swapped my running 5.0 HO out with this cobra. after i swapped it an got everything setup double and triple checked everything. when i began to do the timing it cranked and cranked when i opened the throttle body fully it glugged and then backfired and thats when i stopped. i made sure the number 1 piston was at TDC and then followed the instructions on the rest of the firing mode for the HO motor. could this be that this is not a cobra motor? or do i have the firing mode wrong? what is the correct firing mode for a cobra motor? how can i even tell this is a cobra motor? i heard that you can tell by looking at the serial number and it should have an R in it. in all reality im pissed im stuck and need sime help o and i kept the motor map instead of changing over to maf is that my problem
Old March 1st, 2011, 10:30 PM   #2
FastStang91Lx's Avatar
1991 Mustang LX 5.0
Start over... What year is your car? And if your timing is way off, then it will backfire. Lastly, is this 'cobra' motor supposed to be just a stock spec 93-95 cobra motor?
Old March 1st, 2011, 11:08 PM   #3
the car is an 87 gt the motor came out of a 94 or 95 mustang cobra has a 303 cam and under-drive pulley and a water pump pulley under-drive is smaller than the stock one and the water pump pulley is about the same size car cranks just wont turn over also has new bbk upper and lower with high flow fuel rails and a kirban fpr that has never been set to proper psi. should i put stock fpr on until i get it fired up?
Old March 1st, 2011, 11:23 PM   #4
gripthenboost's Avatar
91 Mustang GT
1991 sliver GT
gripthenboost will become famous soon enough
Are you sure the motor is getting fuel and spark?
Old March 2nd, 2011, 12:30 AM   #5
fogged306's Avatar
89 GT
Are you sure you're at TDC on the compression stroke? How are you checking?
Old March 2nd, 2011, 12:36 AM   #6
ryanw's Avatar
1991 Ford Mustang GT
Can you just put it at 0 TDC and drop the distrubtor in ? Going by the marks on the balancer ?
Trick Flow R intake,
jba headers, 2 1/2" x pipe
flowmaster super 10 mufflers,
255 fuel pump,
3:27 gears
Old March 2nd, 2011, 12:39 AM   #7
fogged306's Avatar
89 GT
If the balancer hasn't spun, yea. If it has, you could be way off on your timing.
Old March 2nd, 2011, 02:48 PM   #8
Firaga's Avatar
1993 Mustang GT
Firaga is on a distinguished road
BBK upper and lower intake mani? Isn't that like.. taking a step backwards?
I have a 93 5.0
I love my car, and all my friends hate it.
AEM Brute Force intake, BBK 75mm TB/EGR, C&L 75mm MAF, Trick Flow Street Upper/Lower, Custom exhaust with Dynomax SuperTurbos, Tokico Rear Shocks
Old March 2nd, 2011, 04:01 PM   #9
it am chacking through the number one spark plug hole and then placing the distributer accordingly and then after it fires i can spin my distibutor to adjust the timming ever so slightly but it had a HO upper and lower on it thats the reason for the changing of the intake manifold. also yes i am getting fuel and spark therfor the result of a backfire
Old March 2nd, 2011, 05:59 PM   #10
fogged306's Avatar
89 GT
What I'm getting at is how are you making sure you're not at TDC on the exhaust stroke.
Old March 2nd, 2011, 11:36 PM   #11
ok i got it to fire runs smooth also found out it is not a cobra it has a non HO motor and i am very pissed. i paid $2200 for a damn van motor good thing i still have my old 302 "HO"
Old March 3rd, 2011, 01:33 AM   #12
fogged306's Avatar
89 GT
So what was your issue?
The only differences between an HO and a non-HO are already changed, so you've technically got an HO engine in there. The heads, block, and rotating assembly were the same. The cam, firing order, computer, and I believe intakes were the only things different. The alphabet cam you have is the HO firing order and you've already got a different intake, and you're running the HO computer if you're running the stock mustang one.
It's not a GT-40 combo (cobra) but as of now, there's no point in doing a swap.
Also, you got hosed bad even if that was a real cobra motor. 2200 is beyond ridiculous.
Old March 3rd, 2011, 01:32 PM   #13
i am running the stock gt computer and it wont fire on the HO firing order and it will on the non HO firing order and it doesn't even sound like a v8 it sounds like a camed out 4 banger. ima try a few thing tonight and see what happens.
Old March 3rd, 2011, 01:44 PM   #14
fogged306's Avatar
89 GT
Are you sure it's a 303 cam then? Because those are HO firing order cams. If it is not an HO cam, then the HO computer won't work either because the injector firing sequence is different also. I believe it's only 4 cylinders that are different so this would explain exactly what you are describing to be a non-HO cam too. If that's the case, then all you would need then is to replace the cam with any performance aftermarket cam, go back to the HO firing order and you would be set.
Old March 3rd, 2011, 08:04 PM   #15
its weird to me im stumped the computer that it had in it before was running on a a9l or an ap9 and it sounded mean now it sounds like a junker but ill get it figured out
Threads Similar to: Cobra or HO wont start
95 Cobra Wont Start zerofx150 94-95 5 April 15th, 2008 08:44 AM
My cobra wont start... Brent Russell 5.0 Mustangs 9 January 29th, 2008 11:14 PM
car wont start Black Five 0h 5.0 Mustangs 8 January 4th, 2008 03:12 PM
car wont start 2007calispecial Modular Mustangs 4 May 18th, 2007 09:05 AM
