noz
Old March 1st, 2011, 10:52 PM   #1
1987mustanggt's Avatar
1987mustang gt
1987mustanggt is on a distinguished road
noz
ok so im picking up a nitrous express starter kit... will i need anything besides the kit to run it properly??? a different intake??? bigger injectors???
Old March 2nd, 2011, 02:58 AM   #2
1989Gt.'s Avatar
1989 Mustang GT
1989Gt. is on a distinguished road
Send a message via AIM to 1989Gt. Send a message via Skype™ to 1989Gt.
Id go with some 24lb injectors.... I have some forsale...
Old March 2nd, 2011, 07:27 PM   #3
FastStang91Lx's Avatar
1991 Mustang LX 5.0
Post the part number of the kit.
Old March 2nd, 2011, 10:41 PM   #4
1987mustang gt
how much 1989gt?
Old March 3rd, 2011, 09:03 AM   #5
302Army187's Avatar
'89 LX 'Vert
10's or bust... Literally.
302Army187 has a spectacular aura about302Army187 has a spectacular aura about
don't need bigger injectors if its a wet kit.
get a step colder plugs, upgrade your fuel pump, run highest octane pump gas you got, and drop 2* of timing per 50hp inciment of shot your using.
H/C/I 302 + nitrous for now... supercharger/turbo soon?
www.youtube.com/Xarmy187
Please support my YouTube channel! My videos don't disappoint!
Old March 3rd, 2011, 09:19 AM   #6
e3sean's Avatar
1988 lx
9.68@142
what intake manafold do you have? if its stock i have a plate kit for it.
<font size=4><b>MILITARY CREW
Old March 3rd, 2011, 08:37 PM   #7
Atomized
gotn20's Avatar
gotn20 will become famous soon enough
plate kits are the way to go for sure. Spray is the bees knees in my book
spray and pray
Old March 3rd, 2011, 09:57 PM   #8
1987mustang gt
its a dry kit.. it comes with plates..that rpm thingy..it has everything..
Old March 4th, 2011, 11:36 PM   #9
1991 Mustang LX 5.0
Everything???? Hmmmm. Fuel pressure cut off switch in case your fuel pressure drops too low it shuts it off. Window switch to activate only AFTER a said rpm (many believe it to be after 3k) and shuts it off before you hit rev limiter (to keep your motor in one piece). Bottle heater or Nano system to maintain bottle pressure to keep from running rich. Purge to bleed off any excess pressure to keep from going lean. Optional timing retard so you can run efficiently on and off the bottle. IT COMES WITH ALL THIS??? If not, you're not as safe as you could be.
Old March 5th, 2011, 12:37 AM   #10
1987mustang gt
window switch yes the bottle warmer yes
Old March 5th, 2011, 11:32 AM   #11
1992 Mustang LX
13.0 @ 105
StangBanger302 will become famous soon enough
Spray after 3K, shut off at 6K...
As I lay rubber down the street
I pray for traction I can keep
But if I spin, and begin to slide
Please dear God, protect my ride
Old March 5th, 2011, 12:08 PM   #12
302Army187's Avatar
'89 LX 'Vert
meh.
these are all extras. don't NEED them at all.
fuel pressure cut off switch is nice, but not really needed if you have a new pump, and your not using a huge shot.
window switch is just a fail safe really, if you miss a shift, which if your not really good at shifting, you shouldn't shift fast enough on spray to miss a gear.
bottle heater is a must IMO, but a nano system is NOT cheap, but does help
don't really need a purge. you can "bump" the system. you arm the nitrous, and during your burnout, ether tap the throttle to WOT real quick, or you can bump the system while your pulling up to the line, rev the motor a few times, then quickly go WOT to activate the system.
Old March 5th, 2011, 01:42 PM   #13
95StangMX's Avatar
95 Mustang GT
what size jets are you going to run??
Old March 6th, 2011, 08:28 PM   #14
1989Gt.'s Avatar
1989 Mustang GT
45 bucks brotha.... there yours lol
